Old 12-12-2011, 03:14 AM
Pashik-K is on a distinguished road
alarm 421(Z) Fanuc 18i
Hello, gantry machine, in the process of drilling, I have an alarm message 421 (SERVOALARM: nAXISEXCESSER (D))
parameters in 2078 = 1 2079 = 200
what causes the error?
Possible solutions?
Old 12-12-2011, 03:46 AM
fordav11's Avatar
fordav11 is on a distinguished road
its just an overload. drill with slower feed and speed, replace drill with new one etc.
Old 12-12-2011, 04:36 AM
error can occur when the axis is not loaded
Old 12-12-2011, 03:14 PM
fordav11's Avatar
some suggestions....
check lube oil is getting to moving parts (bed/leadscrew)
check bedways and/or check lead screw/bearings for damage
adjust gibb strips and/or adjust other things where there is friction and moving parts.
Old 12-12-2011, 06:07 PM
underthetire is on a distinguished road
Crabbing of the gantry, if separate motors for each side of the column. Somewhat common on gantry/bridge mills. Check table tram, if it's out you probably slipped a coupling on one of the 2 axis.
Old 12-13-2011, 04:12 AM
I specify
column has a single motor
Fanuc spokesman advised to change the parameter 2118 = 0, on the machine in the parameter = 1000
what affect this value?
Old 12-13-2011, 06:26 AM
fordav11's Avatar
you said alarm 421(Z). so Z servo is overloaded? if yes that has nothing to do with the gantry loader
Old 12-15-2011, 05:35 AM
continue
on the recommendation of Fanuc parameter was changed in 2118 = 0, the error ceased to appear, the machine worked day without any problems
this morning, for unclear reasons, the machine was wringing drill during drilling, in an emergency log error 9031. after this case the Z-axis moves with a strong shake at low speed, occasionally accompanied by an error of 410
I suspect a problem with a counterbalance (hydraulic)
how to check?
Old 12-15-2011, 11:42 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
421 AXIS EXCESS ERROR
Usually caused by mechanical error lub, ballscrew, gib fault etc
Or error with encoder/scale
I think possibly there is a separate detector / scale on this machine ?
and the difference between the scale and the position coder on the motor became too big.
Alarm 410 indicates the same things but in a stopped state
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 12-16-2011, 06:22 AM
Who can tell how to switch from a linear axis tracking sensor to sensor motor?
  #11   Ban this user!
Old 12-20-2011, 05:02 AM
how to check?
continue ...
linear encoder was turned off, the axis is controlled by a circular motor encoder
Z-axis vibration was gone. So we had a great disagreement between the two encoders.
How to find the cause of vibration?
Problem- Fanuc 18T LED alarm only JerryH Fanuc 18 12-28-2011 06:03 AM
Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? blakemachine Fanuc 1 11-11-2010 12:42 PM
Fanuc OM Alarm 087 ED209 Fanuc 5 11-17-2009 12:15 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Fanuc 3t alarm 087 booster05 Fanuc 12 11-14-2006 06:18 PM
