Old 12-12-2011, 12:56 AM
haitd is on a distinguished road
Mori Seiki Fanuc 3T error
hello everyone. I have a lathe MORISEIKI SL-2 FANUC 3T. Led ER3 in Panel always light and turret not change. Please help me.
Regards
Old 12-12-2011, 09:36 AM
underthetire is on a distinguished road
ER3 is machine alarm. Check your hydraulic pressure, turret limit switches, spindle motor fan etc.
Old 12-12-2011, 10:01 AM
I checked, hydraulic pressure, turret limit switches, spindle motor fan, thats all normal.
X, Z axits and spindle ok.
If you have manual Fanuc 3t, please help me. Thanks.
Old 12-12-2011, 11:59 AM
alexfanuc is on a distinguished road
Probably the turret is out of position?
Old 12-13-2011, 07:29 AM
Right.
I made ​​the turret back to original position, and I think reference position wrong. But I don't know set up reference position.
Sorry for my english is bad.
Old 12-13-2011, 12:21 PM
How did you move the turret?
If you put in JOG mode and then try to move the turret, will it move?
Sometimes when you try to move the turret to any other position in JOG mode then the turret should index automatically.
Regards
Old 12-14-2011, 10:08 AM
I move turret by put into core of hydraulic solenoid valve.
In JOG mode, when I put TURRET INDEX ,the turret not any action.
In DIAGNOSTIC, the signal of sensors and push button ok.
Old 12-14-2011, 04:36 PM
look in the ladder diagram for the turret index signal. It should be a one. Sometimes this sensor fails.
Good luck.
Old 12-15-2011, 01:36 AM
Good luck.
Thanks!
But my machine not have the ladder diagram, only diagnostic table. And I don't have any manual or document for machine.
Do you think the parameters is lost?
Old 12-15-2011, 07:05 AM
If parameters were lost, you would see many alarms at power on. Anyway, check the parameter screen and you should see parameters with values.
In a 3T control you cannot see the ladder in the screen.
Ask in this forum to see if anyone has any documentation for this machine.
It is very hard to find a problem when you don´t have the ladder diagram nor the electric diagram.
  #11   Ban this user!
Old 03-06-2012, 11:51 AM
abid iqbal is on a distinguished road
Post 3t joging failure
Regards
hellow sir i have 3t emi mac machine all function are ok but jog operation is impossible please help me
thanks
abid iqbal
  #12   Ban this user!
Old 03-07-2012, 12:07 PM
Sergiogc is on a distinguished road
If the turret lost its position, you'll need to see how it is being controlled, Probably it is contrlled using a driver, that means that you need to tell to the driver its firts position or home or tool # 1, it is going to be hard because normally I solved many of these problems but using the ladder or schematics...I hope this helps
mori seiki sl-3a with fanuc 6t cmo Fanuc 9 04-04-2012 06:24 PM
Need Help!- Mori Seiki AL-2 Fanuc 10T davesnd Mori lathes 2 08-06-2011 11:01 AM
MORI SEIKI MV JUNIOR system error 912- FANUC O-MC janez9 Mori Mills 2 05-16-2011 07:53 AM
Mori Seiki Fanuc O-T Error EX357 hrhoward Mori lathes 10 11-18-2010 08:05 AM
Mori Seiki Lathe Error 414 KSDeerSlayer Mori lathes 5 09-19-2008 07:33 PM
