Old 12-09-2011, 08:32 AM
Will_0000 is on a distinguished road
Fanuc OT and FMB Barfeed
Does anyone have a complete sample program that explains the programming of a FMB Vario barfeed. It is connected to a Miyano BNC 20S. Due to room available the barfeed has only just been attached. I have been using the lathe for 3 years.
Just slightly stuck on how to call and feed a bar to the stop and so on.
Will
Old 12-10-2011, 06:49 AM
ALEXCOMO is on a distinguished road
I suppose you just do it by M code, chek plc to find the right one, other bar control are do by the control of berfeeder.
But is a new installetion or a old never used?
Old 12-10-2011, 09:48 AM
The barfeed is an old installation, it just hasn't been connected since I have owned it.
The lathe manuel show a M83 to perfrom the top cut of a new bar and M85 will feed a bar to a stop.
From what I can work out, you would have the top cut program and new bar in a sub program which the main program calls when needed?
Completly unsure about this as I can't find an examples and ther are no programing examples in the boxes of manuels I have.
This is what is shown for the top cut example -
M83 = Material Feeder Start
N1 T0100
G0 x0.0 z3.0 T0101
M17
M83
M18
G0 z5.0
G27 x0.00 T0000
N2 T0200
G96 s200 M3
Go x20 z0.00 T0202 M8
G01 x-1.0 F0.09
G0 x 12.0
Z50.0
M84
M84 = Block Delete OFF Reset
M85 is the ANF material feed command and consists of:
M17 - chuck chuck open
M83 Material Feeder start
M18 Chuck close.
Just not sure on the correct program layout.
Will
Old 12-11-2011, 01:52 PM
Then the baarfeed is only able to feed the bar and change it?
If this is true the way is right, use a tool for stop the bar, then run the program the righ number of times, because you must discharge the end of the barUse subrogram or parametric or copy paste
Old 12-11-2011, 02:03 PM
The barfeed has a magazine. According to the FMB manuel (no example programs in it) Bar is loaded in to channel, bar is clamped and pusher bar with collet is pushed on to the end of the bar, once bar is used up pusher bar is retracted with bar remnant and clamped, remnant is ejected. New bar loaded from the magazine and the process starts again.
Does the barfeeder perform this processor on its own when a end of bar signal is received or does this need to be part of the program?
The more I try and work it out the more I get myself into a muddle!
Old 12-12-2011, 02:32 PM
the only way is take a look to eletric connection between cnc and barfeeder....
Need Help!- smw barfeed Hash01 G-Code Programing 1 08-07-2009 01:05 PM
Need Help!- Barfeed programming wganders G-Code Programing 15 06-24-2009 07:36 PM
Need Help!- barfeed 300 jz25180 Haas Lathes 4 06-15-2009 08:39 PM
LNS Barfeed Lazzer65 General Metal Working Machines 4 08-13-2006 04:22 AM
Barfeed Option pinguS Fanuc 3 07-27-2006 10:26 AM
