Old 12-09-2011, 07:26 AM
PDI-Curtis's Avatar
PDI-Curtis is on a distinguished road
Hwacheon Hi-Eco31A M-codes: thread chamfering
I've got a 1998 Hi-Eco31A machine with a Fanuc 18TC control.
Does anyone know the M-codes for chamfering out of thread? The manual does not indicate any M-codes associated with this.
I have a Daewoo Puma 200 from the same year, and it uses M77 to pull out straight, M76 to chamfer out. These don't work on the Hwacheon.
Is it possible that this might be controlled by a parameter instead?
Old 12-09-2011, 08:19 PM
fordav11's Avatar
fordav11 is on a distinguished road
M24 Thread angle pull out off (pulls out straight)
M23 Thread angle pull out on (pulls out at 45 degrees)
these are standard Fanuc codes and go way back to 6T and 3000C
what control does your Puma have?
Old 12-09-2011, 11:28 PM
dcoupar's Avatar
If you're programming a 2-line G76 cycle, I believe the P word in the first line controls the chamfer. P021060 does 02 "spring passes", 1.0 leads chamfer out, and 60 degree threading tool (30 degree infeed). Don't remember needing an M-code.
Old 12-12-2011, 10:04 AM
PDI-Curtis's Avatar
@fordav11:
The Puma also has the Fanuc 18 TC control.
According to the manual for the Hwacheon, M24="air jet and spindle inching" - M23 is not shown.
We do have a Mori SL-4 with Fanuc 6TB, and it uses M23/M24 (as does our Mori SL4 with Yasnac 2000GII control)
@dcoupar:
For the record, I am using G92 to thread with on all machines.
Old 12-12-2011, 08:00 PM
dcoupar's Avatar
Parameter 5130 stores the value for the thread chamfer amount. The manual does say that "A signal from the machine tool, initiates thread chamfering." for G92.
Old 12-13-2011, 06:13 AM
PDI-Curtis's Avatar
@ dcoupar:
I have had to alter 5130 on the other machines before... So I guess I am stuck on trying to find out what the "signal" (M-code) would be to trigger the chamfering... thanks for the input.
Tags
fanuc 18t, hwacheon, m-codes, threading
Mazak vs. Hwacheon stattp General Metalwork Discussion 4 01-17-2012 11:12 AM
Need Help!- G codes and M codes for Mazak Quick Turn T-2 sauli Mazak, Mitsubishi, Mazatrol 0 05-23-2011 11:22 AM
Need Help!- Bar Puller on Hwacheon with Oi-TB Grayling Fanuc 16 08-12-2010 04:47 PM
Hwacheon VMC coloradoskibum General Metal Working Machines 1 11-13-2009 09:47 AM
Thread Chamfering (TC82) fooo Mazak, Mitsubishi, Mazatrol 1 02-14-2008 06:38 PM
