| Hi I'm having a problem running the following program. I'm not sure what the alarm refers to but it must be something I'm missing in the program as I tried other programs and they ran fine. Anyone have any ideas? It's a program to pilot drill a bot hole pattern and I know there are better ways of writing the program but I couldn't get any to work.. o5000(---PCD Pilot Drill---) G21 G90 S1500 M03 G01 X501 Y0 Z58.8 G01 F300 X518.66032123 Y54.35287991 G91 G01 F60 Z-5 G01 F60 Z10 G90 G01 F300 X558.15 Y0 G91 G01 F60 Z-10 G01 F60 Z10 G90 G01 F300 X518.66032123 Y-54.35287991 G91 G01 F60 Z-10 G01 F60 Z10 G90 G01 F300 X454.76467877 Y33.59192717 G91 G01 F60 Z-10 G01 F60 Z10 G90 G01 F300 X454.76467877 Y-33.59192717 G91 G01 F60 Z-10 G01 F60 Z10 G90 G01 X501 Y0 Z150 M05 |
If the above program example is indicative of how its registered in the control, and you haven't just omitted the period (decimal point) in some of the blocks in the example program, for example G01 X501 Y0 Z150, then the control will interpret the numbers by counting three places from the right. Accordingly, G01 X501 Y0 Z150 will be interpreted as G01 X0.501 Y0 Z0.150 and G01 F60 Z-10 will be interpreted as Z-0.010 . The exception to this is if the control is configured to Calculator Form, settable via parameter. In this case G01 X501 Y0 Z150 will be interpreted as G01 X501.000 Y0.000 Z150.000. Regards, Bill |
| In Single Block Mode, in which block does the alarm first occur. Regards, Bill |
| Ah right I was not aware of that! The alarm occurs at the first movement, the spindle starts then the alarm pops up at the following G01 block. The number of decimal places is due to copying the values from a drawing in solidworks. Forgot to add the program loaded into the machine did have a feedrate for the first movement, I just forgot to add it here. I'll give that a try on Monday and let you know. Thanks for the help! |
| Fanuc oi Mate-MC (300 APC alarm problem) | klosr | Fanuc | 9 | 04-29-2012 04:30 AM |
| Need Help!- problem about Miyano TSV-21 Fanuc 0M-A ATC Alarm | ixoxi999 | Fanuc | 1 | 01-24-2012 11:15 PM |
| Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? | blakemachine | Fanuc | 1 | 11-11-2010 12:42 PM |
| fanuc 3t problem ( ALARM 2 VDRDY OFF ) | cncmedcom | Fanuc | 2 | 02-06-2007 01:16 PM |
| Kitamura 3xi w/ Fanuc 16i Alarm problem | thamain1 | Fanuc | 2 | 09-08-2006 03:03 AM |
