Old 11-22-2011, 12:53 PM
Togliatti is on a distinguished road
Safety interlock Fanuc 10M?
Can anyone tell me if there's any provision in a Fanuc 10M control to incorporate a safety interlock which will prevent Cycle Start from occurring unless a user-added switch is closed? The issue is an older cnc machine that never had doors or any kind of enclosure. We're trying to make the machine safer by installing a mechanical barrier between the operator and the spindle, and having the barrier actuate a switch when correctly in position. Any help would be much appreciated.
Old 11-22-2011, 01:10 PM
Al_The_Man's Avatar
You could intercept the E-stop input into the controller, there is a dedicated input for it, you would have to consult the input listing sheet.
Old 11-22-2011, 01:22 PM
Would this put the machine into the same state as if one had pressed e-stop?
Old 11-22-2011, 01:58 PM
Al_The_Man's Avatar
Depending on how the ladder is written, it may just e_stop the controller itself.
Old 11-22-2011, 03:04 PM
fordav11's Avatar
fordav11 is on a distinguished road
there is provision. interlocks were added to an old machine with a 10T at my work recently
Old 11-22-2011, 03:43 PM
Al_The_Man's Avatar
Did they update the documentation? If so the specific input they used would indicate as to whether it is a mod originally allowed for or a new input?
Old 11-22-2011, 04:30 PM
underthetire is on a distinguished road
We put safety mats down, but had Uptime re-write the ladder to accommodate it.
Old 11-23-2011, 01:43 AM
fordav11's Avatar
they (our maintenance people and a Fanuc tech) never update anything.
its all top secret
Old 11-23-2011, 07:02 AM
My personal inclination is to sell the machine-a 1987 Enshu, complete with its barely readable documentation. Failing that, next best bet is probably to install a light curtain and have it trigger "reset" which would stop the spindle and the servos. Several months ago, someone reached in and tried to adjust the coolant hose while the machine was running. The outcome was unfortunate, but predictable.
Old 11-24-2011, 12:39 PM
Dan Fritz is on a distinguished road
It might be best to use the "Feed Hold" signal. That signal is normally closed, so a completed circuit takes the control OUT of feed hold. When the feed hold signal is open, any motion is stopped, and any subsequent cycle start input is ignored. Feed hold will not drop out the servos, so you won't lose axis position or reset the program. If feed hold opens while in the middle of a cycle, then you close the circuit again, you can just cycle start to resume the program. Depending on how the ladder is written, it may not turn off the spindle, however.
You could just wire an external normally closed switch in series with the one on the operator's panel. Both switches will have to be closed in order to run. The signal "latches" internally, so a momentary break in the signal will put the control into feed hold until you cycle start again. Just closing the circuit will not make the machine "take off"
There are also interlock signals for each axis, so a separate signal could be used for X, Y , and Z. Those signals just stop axis motion though.
Try to decide just what you want to happen when the safety barricade is actuated. An E-stop would drop off the servos and (in older controls) will lose axis position also. E-stop will stop the splindle and everything else as well. Feed hold lets you resume a cycle gracefully.
  #11   Ban this user!
Old 11-24-2011, 01:56 PM
You can also see if the control has an external reset input. We use that for safety interlocks a lot. Stops everything without killing the servos.
  #12   Ban this user!
Old 11-30-2011, 02:40 PM
What we need to have happen is an immediate spindle-off and the servos stopped when the curtain is triggered. We can intercept cycle-start, but interrupting a cnc machine while it's doing something is not so simple. E-stop would be the most inconvenient way to do it. Triggering reset is undesirable also as it resets the program to the beginning, and would be an extreme nuisance while trying to edit, set offsets etc, if the light beam were to be interrrupted and causing resets. So the reset command could only be active when the spindle is turning, and i don't have enough knowledge, nor the means of getting it on this 25 yo machine. I like Dan Fritz's Feed Hold idea the best IF we can figure out how to stop the spindle also, as it's the spindle that's the real source of danger.
Underthetire, I don't know if the machine has an external reset input. There are a couple of dummy plugs on Amphenol-type connectors on the panel, but the manual is written in Japanese with hand written notes in something resembling English, so the wiring is a mystery. The age of the machine and the arcane electrical diagrams are working against us. Thanks for the responses, i appreciate the ideas.
Safety interlock in series with cycle start-Enshu VMC? Togliatti Safety Zone 0 11-22-2011 09:51 AM
Tormach 1100 - Safety Interlock Cover BradS. General Metal Working Machines 1 10-21-2011 04:18 PM
Problem- Strippit FC100SXP with Fanuc 0PC. Setting Work Clamps Safety Zone. Malek Machine Problems, Solutions , Wireless DNC, serial port 1 09-06-2011 01:24 PM
Need Help!- Fanuc OM w/ no. 2000 axis interlock alarm bikebasher General CNC (Mill and Lathe) Control Software (NC) 0 05-23-2008 01:59 PM
EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE Epik General CNC (Mill and Lathe) Control Software (NC) 0 02-27-2005 04:20 PM
