Old 11-19-2011, 09:52 AM
capngene is on a distinguished road
Thumbs down Contactor Source wanted
Excel mill uses FUJI SW-03RM/3H, the part is marked SC-03(11 and
relay is Fuji HH52 PL.
I'm looking for cross reference to other manufacturers or an updated part number or a source for purchasing these parts.
Old 11-19-2011, 10:42 AM
Al_The_Man's Avatar
Replacing or sourcing a different make of contactor is not usually that difficult, from the original you need to know the amount of power contacts, 3 or 4, the number of auxilliary contacts and whether N.O. or N.C.
Whether an O/L is fitted and the current setting range.
What is the nature and current of the load, H.P. etc.
What is the coil voltage and whether the coil is AC or DC.
There are many makes available in the US that should fit the bill, Square D (Telemecanique) , Allen Bradley, just to name a couple.
Most of the compact DIN style come configurable with the aux and O/L as add on's
Old 11-19-2011, 03:07 PM
Al_The_Man's Avatar
If it is the same as this, it is not a contactor but a very common relay, should be simple to sub a P&B (Tyco) or Omron etc.
http://www.wp-electric.com/images/co...52%20RELAY.pdf
YASKAWA MAGNETIC CONTACTOR H1-50E HI-50E HI50E CNCadmin EBAY ADS 0 05-06-2011 09:00 PM
What's that gizmo across the contactor coil? jrlandau Bridgeport and Hardinge Mills 1 01-21-2011 11:53 AM
Wanted, bearing races or alternative source for races. joejared Want To Buy...Need help! 1 04-29-2009 08:46 AM
Need Help with Magnetic reversible Contactor Chris64 General Electronics Discussion 12 12-23-2007 02:54 PM
Contactor help ???? Fabric8r General Electronics Discussion 1 05-26-2006 05:27 PM
