advise please, who managed to fix this problem master PCB: A16B-1010-0330 ROM PCB: A16B-1211-0280 I see that error appears when system checks the RAM ROM PCB has been replaced RAM ICs replaced, ecept soldered ones ROM IC's reburned
__________________ Soviet ICs are the largest ICs in the world!!! ))) |
| if I press RESET IPL appears all PCBs are placed correctly a couple of times system booted, but then got hanged
__________________ Soviet ICs are the largest ICs in the world!!! ))) Last edited by guhl; 11-18-2011 at 10:05 AM. |
| when we try make memory dump from address FF3..., sytem shows address FFC... now we suppose that some functional block "address decoder" is fail does anybody have a memory map for 11M series with digital servos?
| Do you have a memory backup? If you have a memory backup you might try to erase memory. Try to power on pushing - and . (minus sign and a dot sign). See if it powers on in the IPL mode. Regards |
#10
| why do you ask me about I/O card? I disconnected all the cards from the masterboard, except PMC cassette and ROM/RAM board this system equipped with BMU memory I can call IPL mode throgh RESET button when the screen shows the content of memory and "SYSTEM ERROR" message now I need memory map to locate the address decoder on masterboard ordinary way to call IPL trough "." and "-" is unavailable
#11
a)you probably are missing one of the PCBs b) you have a short in 24VDC line, (This is why I asked you to disconnect cables to the IO board) c) You lost memory (you must erase the memory and upload all the info again) d) You have a bad master pcb Not all the CNC software will display an alarm in the CRT If you are trying to power on the control with one of the pcb missing you will get a system error and an "E" in the master pcb. Do you have all the parameters of the machine? if so, you might want to erase and upload the memory again. Good luck! |
#12
| alex 24V short usually causes fuse blowing read, please, yellow fanuc book where error "E" is described BTW my machine is Hitachi Seiki with its own PLC and there is no I/O cardson PCB master PCB LED content and its meaning 9 ..... CPU START 8 ..... RAM CHECK --- If it is error, Change to “b” 7 ..... RAM CLEAR 6 ..... BAC INTIALIZE, SDC (Serial DMA changed) DATA TRANSMISSION START If it is error A ..... SDC CHANNEL 0 or CHANNEL 2 COMUNICATION ERROR (MDI/CRT COMUNICATION ERROR) C ..... CHANNEL 0 OR CHANNEL 2 ID NUMBER WRONG F ..... SDC CHANNEL COMUNICATION ERROR H ..... CHANNEL 1 UNIT ID NUMBER WRONG c ..... SDC ERROR LEVEL 7 INTERRUPT (CRT POWER SUPPLY,I/O PCB PROBLEM) J ..... WAITING ANSWER FROM PC 5 ..... READING MDI KEY SWITCH 4 ..... CRT INITIALIZE 3 ..... INITIAL SCREEN (SOFTWARE SERIES AND VERSION DISPLAY) L ..... WAITING PC READY 0 ..... IPL MODE 2 ..... SYSTEM SOFTWARE INITIALIZE 1 ..... SYSTEM START E ..... SYSTEM ERROR
| Need Help!- Fanuc error 998 ROM Parity Error ??? | ED209 | Fanuc | 30 | 04-04-2011 04:19 PM |
| Fanuc Error 449 | dhiruj | Fanuc | 7 | 01-04-2009 12:18 PM |
| Fanuc 6M error 11 | hopcycle | Fanuc | 2 | 03-24-2008 11:01 AM |
| FANUC OMB Error | malasjo | Fanuc | 2 | 12-31-2007 05:23 AM |
| SR 591 - TV error on Fanuc 10M???????Help! | John_B | Fanuc | 4 | 06-29-2007 11:38 AM |
