Old 11-17-2011, 08:10 AM
Chais82 is on a distinguished road
Fanuc 10t controll. Preset retract in canned cycle?
I am running an old Victor cnc lathe. It has a Fanuc 10t control. When doing a canned cycle it is only needed to write one G71 line to perform the cycle.
Example: G71 P101 Q105 D500 U.003 W.0015 F.008;
From what I understand, this control has a preset retract for the canned cycle. Mine is set at .1" retract. The problem with this is, when boring for example, if Im only taking a .01" cut with a bar cutting at its minimum bore I cant retract .1" or it will crash.
So my question is; Where is this preset located? And if at all possible, how can I change it?
Thanks in advance!
Old 11-17-2011, 09:28 AM
stevo1 is on a distinguished road
IIRC it should be parameter 6215 for the retract amount in the G71 and G72 cycles. You will have to set your PWE bit in parameter 8000 while in MDI mode in order to change this parameter.
Stevo
Old 11-19-2011, 03:08 PM
gbowne1 is on a distinguished road
Yeah, thanks for this one stevo. I've actually been working on the 6000 parameters for the 10TF this week. Didn't realize there was a preset retract for the G71 & G72.
I usually use a 1/64" (.015") min. retract on lathe boring cycles.
Parameters for the 7000, 8000, 9000 are due finished by Jan 2nd, 2012. That way when the guy comes to put them in my control he can write the ladder, etc.
Old 11-21-2011, 07:19 AM
Your welcome Greg.
Stevo
Old 11-24-2011, 01:41 AM
Well I've been using parameters I obtained from several lathes with 10t controls to use as a guide to setting my parameters since I wasn't able locate a good parameter manual or a guide to use as a reference. And i've never set up a lathe control before.. I just wish there was a better guide to what every parameter is, does, etc. I just Hope I've got all the axes parameters set right.
Old 11-29-2011, 11:45 AM
I hear ya Greg. There isn't much for documentations when it comes to that. I have been unable to locate the 10series manuals either. I usually reference my 15series as they are pretty close. I had a set of 10series operators, maint, parameter manuals but I left them at my last place. I regret it greatly especially how hard it is to locate these now.
Stevo
Need Help!- FANUC SERIE 0-MC CANNED CYCLE renato13 Fanuc 1 05-27-2011 10:18 PM
Need Help!- Fanuc Series 20-TA (G90 canned cycle) firekoe Fanuc 4 01-01-2010 09:44 AM
Newbie- Canned Cycle - Fanuc oi Trevorweb G-Code Programing 6 03-12-2009 09:08 AM
Fanuc Canned Cycle MACROS kuyohtay Fanuc 9 05-20-2008 03:40 PM
G90 (Canned turning cycle) Fanuc 21i-TB ? Jdavis733 G-Code Programing 0 01-23-2008 08:18 PM
