Old 11-14-2011, 08:11 PM
kisssj is on a distinguished road
MAKINO FANUC15-MB MPC2 nitializtion
MAKINO horizontal machining center in which made in Japan, model number MC98, system with FANUC15-MB + External config PLC fitting: MPC2. The MPC2 was made up by 2 CPUs, one is MAIN CPU (A16B-1000-0110); another one is SUB CPU (A20B-1000-0550). And now the situation is the saving data of MPC2 was lost because of battery problem. PAL fault indicating lamp of MAIN CPU was on, can not open PLC system to adjust data (power off of when pressing NC/PC), anyone who can help me pls kindly advise, looking forward to hear from you soon!
Old 11-15-2011, 09:05 AM
Robert Zmigro is on a distinguished road
kisssj I ran a Makino vertical 20 some years ago, and I believe you can replace the battery by opening the back cover plate on the control unit. You may have lost the program you were working on, but it should probably restore the defaults. good luck!
bobz
Is there anyone using Makino a81? hexa General Metal Working Machines 2 07-18-2011 05:25 AM
Need Help!- Makino E33 Tim1 Vertical Mill, Lathe Project Log 0 06-18-2009 11:06 AM
Makino A66 emexcee380 General Metal Working Machines 0 02-02-2009 06:06 PM
Need Help!- makino mc 86 rathi_vk General Metalwork Discussion 0 02-01-2009 09:41 AM
HELP!!!!! Need Makino J88 Bluesman Employment Opportunity 2 10-30-2007 07:47 AM
