only if its in the ladder...look in diagnostic around 290, press the buttons, see what bit they are, then search that bit in the ladder see if there might be a 'D' address with inverse contacts from the 290 bit to some other bit...(wont be a direct input bit from the rotary, its a 4 bit binary pattern decoded in logic or with a code conversion block instruction to sort out the rov1/rov2 signals.
kinda doubt they have the option in the ladder, but you never know...
if I might ask, why do you prefer the rapid separate? we have a few like that, but usually if we do any work in the ladder side i'll put it on the dial so its more like the bulk of our machines...just curious on if it might be better the other way around, always appreciate any/all input on making stuff easier/faster for production![]()
LinkBack URL
About LinkBacks
