Old 11-10-2011, 06:14 PM
PICMAN's Avatar
PICMAN is on a distinguished road
FANUC 18-M LEADWELL
Hello,
I keep getting a 414 alarm x,y,z,b axis detect error followed by a 751 spindle-1 detect error (AL-51) on my machine. I've checked the power coming in across L1,L2,L3 getting a reading of 205 V AC. When I command the spindle to turn faster than S1000, the spindle drops out and gives me all 5 alarms. I wonder could I have a loose connection somewhere? I made sure everything was tight and repeated the process of homing the machine and trying to command the spindle again, but same results...... I could use a lil feedback.
Thanks,
Picman
Also the alarms read 51 on the spindle amp
and read 04 on the power supply
Old 11-11-2011, 06:40 PM
alexfanuc is on a distinguished road
Originally Posted by PICMAN View Post
Hello,
Thanks,
Picman
You probably have a bad power supply. Is it an alpha power supply?
Alpha power supply part number A06B-6087-H115? besides the spindle drive unit.
Regards
Old 11-14-2011, 08:21 AM
PICMAN's Avatar
Cool PROBLEM SOLVED
Hello,
I finally figured out that my 4th axis, for whatever reason was drawing too much current. I turned off the parameters and quit getting the alarms. I must have a cable problem.
Thanks,
Picman
Need Help!- Leadwell, fanuc O-T help! Vegabond Fanuc 81 11-22-2011 06:29 AM
Problem- FANUC 18-M LEADWELL PICMAN Fanuc 4 08-22-2011 07:29 PM
Leadwell Fanuc ot unıt mustafaguler Fanuc 2 05-26-2011 05:48 PM
Need Help!- Fanuc 21-M Leadwell V-30 1997 Neutronix LTD General CNC (Mill and Lathe) Control Software (NC) 1 04-24-2011 06:38 PM
Need Help!- Leadwell MCV 550 Fanuc OM-A KLPerformance Fanuc 2 03-21-2011 11:16 PM
