Old 11-04-2011, 07:41 AM
Warek is on a distinguished road
Fanuc Mate TS
Hello
I have Gildemeister NEF 400 with Fanuc Mate TS ( very old system ) please help me with data transfer between laptop and machines
How to connect RS232
How to make transfer
Old 11-04-2011, 11:25 AM
fordav11's Avatar
fordav11 is on a distinguished road
the method and cable must be similar or identical to standard rs232 cnc hook-up.
you may need to check some parameters but because your control is not common without a manual it will be almost impossible with no parameter list. its possible the communication parameter numbers are the same as 10t/12t/15t/16t etc.
see this post for more info....
http://www.cnczone.com/forums/fanuc/...nuc_21i-t.html
there are dozens of rs232 transfer questions here. please do a search and read them. search is up top in the blue menu
Old 11-04-2011, 03:29 PM
angelw is on a distinguished road
Originally Posted by Warek View Post
Hello
There is usually another character used in the designation of the Mate control, ie O-Mate. Do you have any other identifiers of your control? When the control is booting, you should see the control model displayed.
Regards,
Bill
Old 11-07-2011, 04:38 AM
Thank for answer
I check identifiers of my control probably in thursday
Old 11-14-2011, 05:28 AM
I attach photos of the machine control panel
ID:	145989   Click image for larger version
ID:	145990   Click image for larger version
Old 11-14-2011, 07:32 AM
fordav11's Avatar
have you made a standard rs232 cable yet?
if not you can not go further until you make a cable, plug it in and at least try it with common transfer software.
the control looks like older Fanuc 3000C control. it is possible to use rs232 connector to punch/read.
Fanuc O-MD or Oi-mate? Genguy General CNC (Mill and Lathe) Control Software (NC) 3 08-19-2011 04:15 AM
Fanuc O-Mate M dnc diemaker General CNC (Mill and Lathe) Control Software (NC) 1 05-09-2011 02:52 PM
fanuc 0 mate M dasandy General Metal Working Machines 2 07-21-2010 08:47 AM
G76 in Fanuc Oi Mate m_ghaff2000 Fanuc 1 07-14-2008 01:53 AM
fanuc mate M dasandy Fanuc 6 06-12-2008 05:00 AM
