Old 11-02-2011, 12:20 PM
mousongie is on a distinguished road
FANUC Oi TB WORKSHIFT PROBLEM
Hello Mates!
Im operating a Victor V26 of Fanuc Oi TB series, having problem with the WORKSHIFT assignement format or command.
Just like on other machines, i will face the workpiece with the roughing tool, and move up the tool on the X axes, open the WORKSHIFT page, go the Z post and press; MZ0 input, or Z0 MEASURE (Soft key).
Here is the problem; when assigning the GEOMETRY offset,
the Z0 MEASURE (Soft key) option works perfectly. But when i open the WORKSHIFT page and input that format (command), the MEASURE (soft key) doesnt appear. Surely im missing up something. Would someone help me with the correct format of the WORKSHIFT on Fanuc Oi TB. Thanks in advance.
Old 11-02-2011, 12:44 PM
tanvon's Avatar
tanvon is on a distinguished road
hi, I don't think there might be any other problem but incorrect mode selection.
tanvon malik
http://www.visinia.com (CNC Programming Blog)
Old 11-03-2011, 02:29 AM
fordav11's Avatar
fordav11 is on a distinguished road
you're obviously used to some other controls like Fanuc 10/11/12/15/16/18 series.
On 0i series there is no measure to set the workshift.
Move your workshift setting tool to the face. We will call it Z0 position.
Go to workshift page and on the right side you will see MEASUREMENT and a X and Z.
Put the cursor on the Z and type 0 and press INPUT
On the left side the workshift Z SHIFT VALUE number will change.
Your workshift is now set so the face is Z0
If you need to move it in some amount (say 1.0mm) simply put the cursor on the
Z SHIFT VALUE (left side of screen) and type your shift amount and press INPUT+
(i.e. 1.0 INPUT+)
Old 11-07-2011, 11:12 AM
Thumbs up
(i.e. 1.0 INPUT+)
Thank you so ever fordav11 for your input. Your direction took me straight to the right place. Thank you for opening this secret to me.
Setting Workshift 00 rylanrouge General Metal Working Machines 1 07-22-2011 05:29 AM
21i-T and Workshift big_mak Fanuc 1 03-02-2010 10:19 AM
fanuc 18T workshift question? cuz1007 Fanuc 2 03-02-2009 06:20 AM
Workshift in fanuc peaceandcalm Fanuc 10 09-23-2007 05:43 PM
g52 workshift dertsap Mach Software (ArtSoft software) 2 04-04-2006 05:32 PM
