Old 10-30-2011, 12:44 PM
emind is on a distinguished road
lost Data hitachi seiki HT 20
I have a 2nd hand HITEC-TURN HT20, Serial N°22245, Constructed 14/10/1986, which I bought recently. As it didn’t work since long time, it lost all data table. With the help of friend I found some of them. But the data specific to “HITACHI”, DATA TABLE, DATA CONTROL, DATA N° D0000-D0002-D0010-D0018-D0026-D0034-D0042-D0050-D0058-D0066-D0074. All of this parameters contain 7 Bits. This DATA concern spindle speeds and tool post rotation.
And the DATA for PC counter and PC keep relay.
Please, If anybody have this type of machine, help me please.
Old 10-31-2011, 03:48 AM
cnc-it's Avatar
cnc-it is on a distinguished road
Hi are you looking for parameters for the Fanuc side or the Hitachi PMC side? Does it have a Micon 8 controller on the cabinet door?
John
Old 10-31-2011, 07:11 AM
what's Micon 8 please?
parameters for the Hitachi PMC side.
Thses parameters concern spindle speeds.
Old 10-31-2011, 02:18 PM
cnc-it's Avatar
Hi the Micon 8 is an Hitachi PMC found on lathes of this age. Is it a Fanuc 6TB controller?
John
Old 10-31-2011, 05:04 PM
John
Hi John,
I don’t know how can I fin dit , but my CN is Fanuc 10T.
Old 11-01-2011, 01:43 PM
Angry
Hi all,
My real problem is when I program M03 S4000; machine t urn only 1022 RPM.
Same for any other spindle speed. Only 1/3 of the given speed realized.
And I don’t have an operator’s manual for programming this machine.
System runs with FANUC 10 TE-F
Year 1986 October. TYPE; TTV-32DKL
Find my front panel as an attachment file.
Regards.
Name:	CNC Front panel.jpg‎
Old 11-02-2011, 12:59 AM
Capt Crunch is on a distinguished road
Hi
i have the same control on the hitachi Fanuc 10 te f that i run. try m41 before the g96 command, this is high gear / range. the machine will default to m40, low gear / range. m40, m41 MUST be commanded by you. hope this helps. enjoy the day
ps, do you have FAPT on this machine?
Old 11-02-2011, 08:01 AM
Hi Gerry,
Thanks for the help. I’ll try it in this evening.
Yes I do have FAPT on this machine. But it doesn’t work also.
There is an alarm “parity error”
Please tell me do you have the programming manual for this machine?
I tried the drilling cycle with G74 as;
G74 R.3 Z-20. Q1500 F.08; but it doesn’t.
Regaeds.
Old 11-02-2011, 08:11 AM
fordav11's Avatar
fordav11 is on a distinguished road
I've been using FAPT/CAPS etc for around 20 years. If you need to know anything about FAPT programming just ask.....
G74 format is...
G74 Z (end point in Z axis) K (peck amount) F (feed rate)
there are other items on the G74 line but they can be omitted when peck drilling.
Old 11-02-2011, 04:01 PM
Smile
Hi Gerry,
I try M41 and M40 on my machine. Yes, you are correct about these two codes.
Machine by default turn on M41 mode.
I explain it to my friend how helped me to get the machine done.
So he shows me on the screen the path, to copy from another machine, as follow;
• Click on NC/PC button
• PCPRM bottom screen
• DATA bottom screen
• You find the page, DATA TABLE CONTROL DATA
From D000 to D0074.
Please be kind to copy these and send me.
This photo show you the page.
Regards.
Name:	DATA TABLE.jpg‎
  #11   Ban this user!
Old 11-02-2011, 04:05 PM
Smile
Thanks for the help. I’ll try it tomorrow.
Regards
  #12   Ban this user!
Old 11-02-2011, 07:54 PM
hitachi 10t f
Bon Jour
i will have a look this weekend. hold the BS key as you power up, it should get rid of this parity error, we had the same problem. i will look for the parameters that were down loaded and send them to you. hope this helps.
Need Help!- lost Data hitachi seiki HT 20 emind Fanuc 1 10-19-2011 02:21 AM
hitachi seiki HT20 Data probleme emind CNCzone Club House 0 10-18-2011 12:26 PM
Need Help!- Fanuc 21i-M lost all data with no backup ar89 Fanuc 2 09-07-2011 11:11 AM
Problem- Did Mori Seiki Buy Hitachi Seiki? Billet Sean Mori lathes 6 05-04-2011 10:12 PM
Need Help!- rover 336 data lost freezengate CNC Machining Centers 19 11-17-2010 03:07 PM
