Old 10-24-2011, 08:38 AM
guhl's Avatar
guhl is on a distinguished road
0TB multiple subprogram call
How to call subprogram several times on Fanuc 0TB?
Soviet ICs are the largest ICs in the world!!! )))
Old 10-24-2011, 09:16 AM
dcoupar's Avatar
M98 P00123456 calls sub O3456 12 times.
M98 P00041111 calls sub O1111 4 times.
Old 10-24-2011, 05:20 PM
guhl's Avatar
thanks
wiil try
Old 10-28-2011, 03:55 AM
sinha_nsit is on a distinguished road
I have not tried but read somewhere that P-word can have only seven digits, allowing a maximum of 999 repetitions???
Old 10-28-2011, 07:12 AM
cnc2149 is on a distinguished road
The 0-TB Operators Manual specified a 7 digit P-word and states that a call command can specify up to 999 repetitions of a subprogram.
The 0-TC Operators Manual specifies an 8 digit P-word and states that a call command can specify up to 9999 repetitions of a subprogram.
Old 10-28-2011, 08:28 AM
dcoupar's Avatar
Sorry. I only have access to a 0T-C manual. I guessed the B was the same, but I guessed wrong.
Old 10-28-2011, 12:27 PM
Your original reply was fine in that it presented the correct solution methodology. These forums are useful in not only solving the particular problem reported by the original poster, but also inform and educate others with various FANUC CNC models.
Since FANUC's controls do vary somewhat in capabilities, if he encountered an error when running an 8 digit P-word on the 0-TB, he could go to that appropriate CNC manual and figure out the error.
btw: I had no idea of this slight operational difference in the 0-TB vs 0-TC until after I checked on the question in sinha_nsit's post.
Old 10-29-2011, 03:11 AM
The best thing is to check on the machine. Manuals sometimes give contradictory information. For example, on page 129 of 0i-TC Operator's Manual, maximun repetition count is stated as 9999, but in the given syntax, only three spaces are shown for repetition count (followed by four spaces for subprogram number).
And, IIRC, OiMate-TC ignores the eighth digit from right. But 9999 repetitions are still possible with L9999.
Rhinocam and multiple spindles and or multiple tables? brett gallmeyer Rhinocam 0 02-23-2011 01:30 PM
Newbie- Can I call a subprogram from within a canned cycle? TXFred G-Code Programing 5 12-09-2010 04:59 PM
subprogram krow OKK 0 09-30-2009 05:18 PM
Need Help!- OKUMA Mill Poste Edit for " NCYL " subprogram call QAZEWQ Mastercam 7 06-14-2009 08:56 AM
eia subprogram rs1982 Mazak, Mitsubishi, Mazatrol 4 04-11-2008 08:10 AM
