| Hi Have a cnc- millingmachine, Leadwell MCV-760 CR with fanuc o-m control system. I have a problem with the tool changer/magazine, I can only use 14 out of 24places. When I try to call a tool higher than 14 I get an alarm code "1037 T.no not registered". If you need more info, just ask. Greateful for help! |
| I don’t know exactly how it is going to be setup in your machine control but this is typically set on the PMC side of the control. There should be a tool table that you can set the tool and life of the tool there. If they are not set then you will get the alarm. Stevo |
| I have a leadwell VMC with Oi-MD control. This has the Leadwell ATC software. With this you can "unload tool" i.e leave certain pockets not available. I have a large oversize slit saw (T19) and either side there are empty pockets (T18 and T20) are not available and would give an error if I called them. On your MCV you might have to tell the software that tools 14 to 24 are loaded. Don't know if your O-M MCV control is the same, but might be worth a try? ATB |
I agree with you, there should be a way to load and unload tools, the problem is that we dont know where to do it. We have spent some time going through the menus and we have found a tool library but there does not seem to be a way of loading/unloading tools there. Regards |
| Leadwell, Tool select problem... | jgabriel1983 | Controller & Computer Solutions | 2 | 10-30-2011 12:11 AM |
| Need Help!- 0ma tool changer problem | curtistdc | Fanuc | 3 | 06-14-2010 06:20 PM |
| tool changer problem | kling8 | Mori Mills | 2 | 02-25-2010 07:54 AM |
| Need Help!- Torq Cut 22 Tool Changer Problem | MetalicGlow | Bridgeport and Hardinge Mills | 8 | 12-08-2009 07:41 PM |
| tool changer problem | concordezz | Haas Mills | 10 | 08-20-2008 03:04 PM |
