Old 10-19-2011, 01:37 PM
nazdackster is on a distinguished road
Input Range for Tool Radius?
I have a RoboDrill 31i with #12003 (tool 3 radius) set at 33.5 and guarded so the input can only be 33.5 to 33.51. I want to open that up, but I can't find the input range guarding on the 31i control... Any help?
Old 10-19-2011, 04:31 PM
Found it... Offset, right key, offset, OPMT, change (or something like that)... I could get to the wear, but not to the radius. The change soft key gets you to the next set of numbers. Thanks anyway...
Need Help!- tool radius correction micktat Deckel, Maho, Aciera, Abene Mills 4 02-24-2010 03:57 PM
G42 Tool nose radius. al-108 Okuma 5 03-02-2008 01:39 AM
Need Help!- Tool Nose Radius speeeeed Haas Lathes 5 02-25-2008 04:11 PM
Problem- tool change stalls in high speed range productservice General Metal Working Machines 2 02-20-2008 05:52 AM
Tool radius comp cijunet Mastercam 5 12-20-2007 03:27 PM
