Old 10-19-2011, 03:08 AM
Chizz is on a distinguished road
fanuc robodrill t21if (dripping from card?)
hi there this is a bit of a long shot but does anyone know how to set the machine up so it will read directly from the memory card we were dripping from the computer using a program called cimco but our anti virous software will not allow it to run any more. And at the minute we are only able to run prog's that fit in the control.
any help would be much appreciated.
thanks chizz
Old 10-19-2011, 04:09 AM
fordav11's Avatar
fordav11 is on a distinguished road
do you mean run programs directly from the memory card slot that is next to the screen?
or some other type of built-in controller card?
Old 10-19-2011, 04:26 AM
fordav11's Avatar
oh I see you said 'memory card'
1. set the I/O channel to 4 (in settings)
2. enable PWE (in settings) and set parameter 138 bit 7 to 1
3. put memory card containing your CNC programs into the slot
4. select TAPE mode
5. press PROG then soft key '+' until you see 'DNC CD' soft key item and select it
6. from the displayed list of programs enter the program you want to DNC
7. select 'DNC ST' soft key item
8. press cycle start
you can call up a sub-program on the card by having the above parameter 138 bit 7 set to 1 and also parameter 3404 bit 2 set to 1
then instead of M98 to call the sub program, use M198 Pxxxx and it will call program xxxx from the card.
Old 10-19-2011, 07:45 AM
thanks for the reply i get all of that except where to locate the (2. enable PWE (in settings) and set parameter 138 bit 7 to 1) i just cant find it do i need to be looking in a different settings part all i am seeing is (basic,measure conditions, calibration, and maintance) proberly looking in completely the wrong place thanks for your help.
Old 10-19-2011, 09:10 AM
fordav11's Avatar
I'm not familiar with your exact control. You should have a hard button on the panel named 'setting'. press it and you should see a screen like shown below. or find it on your control, maybe via maintenance?
you need to turn on parameter write enable (PWE) then set those parameters I said and change the I/O device to 4. If you can't do that or have no idea what I'm talking about then you'll have to get someone at your company who knows more to do it for you and/or search these forums for general info on doing that. It's all over here, there are hundreds of posts about changing parameters. Alternatively the procedure is explained in detail in your operation manual and parameter manual.
Need Help!- FANUC ROBODRILL zavateandu Fanuc 2 05-25-2011 08:48 AM
Need help dripping from PC Card speedygoss LittleMachineShop CNC Machines 1 03-07-2011 10:44 AM
Need Help!- fanuc robodrill gergelb Fanuc 1 03-24-2010 05:43 AM
Need Help!- Fanuc Robodrill t14-ial Mikko K Fanuc 9 03-03-2010 04:06 AM
memory card problem on robodrill aimcnc Fanuc 3 03-20-2009 04:38 PM
