Old 10-17-2011, 09:43 PM
stevenchan is on a distinguished road
Macro program For DAH LIH - MCV610
Dear all:
Has any one have the Macro program for the Tools Change ?
the Machine is use Fanuc System 10M
its loss all the parameter and the Macro program..
we have the Parameter.. but we don't havethe macro program for tools change
the Machine Brands is "DAH LIH"
Model : DL-MCV610
Date :1982
Seri : 610149
Old 10-18-2011, 05:36 PM
stevo1 is on a distinguished road
First thing that we are going to want to do is find out how your machine does a tool change. Either by custom macro or ladder. It could also be both. Before explaining to much let us know what the settings of the following parameters are.
7071-7079 (calls programs 9001-9009)
7080-7089 (calls programs 9020-9029)
And the setting of 7000.2 (calls program 9000 via T() command.)
These are the parameters that will be set to call a custom macro program. If any of them are set =6 then that will be the program number being called. Once we have established that we can start on the code.
Do you remember the machine running a macro or not?
Stevo
Old 10-18-2011, 09:47 PM
Dear Stevo1:
we know for to call the macro.
the problem is we not know what "M code" to command function the Unclamp,forward the tools cylinder,and the other mechanical for tools change..
Old 10-19-2011, 11:55 AM
All of those details should be taken care of via ladder. We need to know if a macro was called. If you know that macro program number let us know. If you do not then tell us what the above parameters are set to.
Stevo
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
macro program editor mike9696 NCPlot G-Code editor / backplotter 3 01-21-2009 06:08 AM
Macro Program for Eumach VMC L. Sakthivel Fanuc 4 10-07-2008 12:05 PM
G65 macro B PROGRAM gollame G-Code Programing 2 05-11-2008 11:26 AM
Macro program pioneerproducts Product Announcements & Manufacturer News 4 10-08-2007 03:44 PM
