Old 10-16-2011, 02:40 AM
M.RISHIKESH is on a distinguished road
Nigata HN63D with Fanuc 18i
Dear All
Error 387 : X axis Encoder fault (External) fault is coming, mostly due to some fault in Linear Scale
We have referred to Nigata Manual to bypass Scale
Please refer to attachment Nigata.doc
Till now Machine was running in Scale mode so we do not know how parameters like 2000 bit 0 , 2023, 2043, 2044, 2047, 2053, 2054, 2056, 2074, 2128, 2129 match with the one for Encoder Mode although Machine was running in Scale mode and we never changed these paramters before. We have compared these parameters with another exactly similar Nigata Machine, in those machines also paramters are similar to this machine.
Also Paramters like 2024, 2057 and 2085 neither match with the list for encoder mode nor with the Scale Mode
To bypass Scale, we made 1815.1 as 0 and 2018.0 as 0, 2084 to 2, 2085 to 125, after switch off and ON, No error appears but when we move X axis, it moves but when we stop moving error 410 : X axis excess error appears, also in MPG (Handle ) Mode, we found that axis continues to rotate little further even after we stop moving axis using handwheel
Kindly let us know which all parameters to be changed to avoid error 410
Best Regards,
M. Rishikesh
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
need serviceman for nigata en50 billystein CNC Machining Centers 1 02-10-2008 10:02 AM
need nigata mechanic. billystein General Metal Working Machines 1 01-29-2008 05:46 PM
Nigata Fanuc 3M nastek Fanuc 3 06-30-2007 09:31 AM
