| Same motor/encoder except B577 has taper shaft. Al.
| Actually, with this particular motor, the standard shaft is taper. Here is the decoding for this one. It does not apply to all FANUC alpha servo motors. A06B-0127-Bxyy X : 0 (taper shaft -- standard) X : 1 (tapers shaft with brake) X : 5 (straight shaft) X : 6 (straight shaft with brake) YY: 75 (pulse coder alpha A64) YY: 77 (pulse coder alpha I64) YY: 88 (pulse coder alpha A 1000) Note: There is often a suffix after the the -Bxyy which can call for straight shaft with key, IP67, special bearings, etc. Too many to list. |
For some reason I read it backwards. ![]() Al.
| Numbering program lines | tz1238 | SolidCam | 3 | 08-24-2011 06:26 AM |
| Numbering 88hs tools | Ryanscustom | Fadal | 4 | 08-12-2011 08:07 PM |
| macro for serial numbering? | Mark Pelnar | Okuma | 2 | 05-07-2011 04:41 AM |
| Tool Numbering, What's Your Method? | David Bord | Tormach PCNC | 16 | 03-08-2011 04:20 PM |
| line numbering | xairflyer | G-Code Programing | 4 | 05-10-2005 02:22 PM |
