Old 10-06-2011, 07:11 AM
guhl's Avatar
guhl is on a distinguished road
unknown 587 p/s alarm on fanuc 0TB
587 p/s alarm
appears when I try to command the second turret
Soviet ICs are the largest ICs in the world!!! )))
Old 10-06-2011, 03:29 PM
stevo1 is on a distinguished road
Hey Guhl,
I don’t see any reference to a PS587 alarm. The maintenance manual says there are macro alarms in 500-599 range that are sometimes mistaken for the OT alarms but the OT alarms are usually used along with the description of the alarm. Do you have a description with the alarm?
Stevo
Old 10-07-2011, 12:31 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Stevo1 is correct this is a custom macro alarm.
you would need to find the section in your macro #3000=87 and work backwards to find the cause
*edit:* Note: The lower 500's can also be overtravel alarms the '8' in 587 signifying it would be the 8th axis
Name:	0iB Custom Macro Alarms.jpg‎
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 10-09-2011, 12:05 PM
guhl's Avatar
thanks, guys
problem has been solved by clearing all the memory
in fact it appeared when I increased memory
it looks like some waste got into memory after deleting files (par 901)
and, BTW, it is not only custom macro alarm, and also macro executer (yellow box on motherboard), therefore I was't able to inspect macro statements
Old 10-10-2011, 07:37 AM
Glad you got it firgured out Guhl.
Stevo
Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? blakemachine Fanuc 1 11-11-2010 12:42 PM
Newbie- unknown ajmazzsr Shopmaster/Shoptask 1 06-06-2010 12:32 PM
Fanuc 403 Alarm blakester Fanuc 15 05-27-2009 01:54 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Unknown Fanuc PSM ulihuber Fanuc 2 08-10-2006 07:13 PM
