i have a fanuc controler on a revolver head milling and i want to change the parameters from: this is now : G03 X20. Y45. R65.to this : G03 X20 Y20 R65i want the dots to dissapear, i just want the dots to go away |
| that is impossible on a Fanuc control. The point must be there. X20.0 without decimal would equal 20 in the least increment least increment is 1 micron so 20 = X0.020 or 20 microns There is no reason to not want decimal points. Just accept it and move on (and forget Okuma with its non-standard no-decimals) |
RAInB, What model Fanuc control do you have? Regards, Bill |
there is one possibility If you can send the program from PC to machine. But Why you are doing this and What is the Use for removing the decimal I am totally not understand.in 8 years of my service life of CNC i met first time this type of Q. |
| There is no requirement to send the program from a PC to attain what the OP desires. If the DPI bit is set to 1, as discussed in post #3, then X20 will be evaluated as X20.0, no matter how the program is registered in the control. Regards, Bill Last edited by angelw; 10-06-2011 at 06:06 AM. |
| Regards, Bill |
Thx Bill, I`ll try this monday, and i`ll come back with the result |
#10
| I set all of my machines up to use calculator method. As Bill has stated it is all preference. My largest reason is that if someone is typing in a clearance plane of 5”and forgets to put the decimal in I don’t want the machine reading it as .005” Stevo |
#11
I believe our Fagor 8025 controls are set this way, but I use decimals out of habit since all our other lathes are set to use decimal points. |
| GE Fanuc & FANUC proprietary posts | CNCadmin | Fanuc | 44 | 01-05-2012 08:54 AM |
| FANUC & GE FANUC Repairs | RRL | Product Announcements & Manufacturer News | 1 | 04-17-2011 11:50 AM |
| can fanuc ac digital servo amplifiers be run by a controller other than fanuc? | js412000 | Servo Motors and Drives | 5 | 03-09-2011 09:11 AM |
| Fanuc & GE Fanuc Repairs | RRL | Product Announcements & Manufacturer News | 0 | 10-01-2008 12:42 PM |
