I have a 0-MC with software version 0461-D2. In MDI mode, if the reset button is pressed, the work coordinate changes to G54. I have tried changing Par. 394.6 WKZRST, to both 0/1 (original parameter list was 0) but the coordinate still changes to G54, no matter the setting. What am I missing? |
| Work around, while in MDI, program your work offset back in.
__________________ http://www.kirkcon.com/ |
LOL...Isn't the way a machine is "supposed" to work the way the machine tool builder built it?
| well there's always something annoying that needs a minor adjustment. For example on Mori's (and possibly all Fanucs?) the memory key has to be in the write protect position to run it. Being a programmer I'm constantly altering stuff until its perfect. I prefer to leave the key off so I fixed it with a PMC setting. I don't care how the machine builder thinks its done |
| @ford - I understand. But, most of these guys don't know the difference between G-code and ZIP code. Having them change parameters is usually setting them up for a train wreck. Now, I enjoy a good train wreck once in a while. So, if that is the point in changing parameters, then let's get to it. Heck, I bet most of them do not even know that the bit numbers of parameters read right to left and start with 0. Maybe parameter changing should be left to people that have, oh say, 6 years of experience and can actually manually edit G-code with successful results? Just saying. ROFLMBO
#11
| Well structured programs are those that require minimal input from the operator for the machine to operate safely and efficiently, and allows for relatively fool proof tool repeat/restart when required. Relying on remembering to reinstate the work shift offset via MDI every time a Reset is made is potentially a prang in waiting. Every good programmer I know include the work shift offset in the code for each tool in the program. Even if the work shift were model, this code is too important to be left to chance. They certainly don't rely on the operator keeping the machine safe via MDI. As stated earlier, that task must be remembered every time without exception, and has the added hazard of incorrect inputs. Regards, Bill |
| Tags |
| fanuc, fanuc 0-m, parameter |
| Problem- 1994 HURCO BMC 30 - System Resets itself | musnar | HURCO | 0 | 04-27-2011 08:47 AM |
| Need Help!- z zero resets on me | antatps3 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 04-01-2009 08:16 PM |
| Need Help!- Home/Limit Resets without CNC Moving | Mr.Chips | General Electronics Discussion | 13 | 01-13-2009 04:47 PM |
| M2 Resets Common Varibles? | jamesweed | Fanuc | 5 | 04-11-2007 05:56 PM |
| Spindle motor shuts off at start up and resets machine. HELP! | Huntersyv | Phase Converters and VFD | 27 | 04-03-2007 01:50 AM |
