Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: G76 quit working on OT-C control
  1. #13
    Sep 2010
    Are you still using 15 Series format, ie., single line with K, D, A etc? If so, the parameters 0109, 0723, 0724, 0725, and 0726 don't apply. Is the tool tip angle specified in the G76 block still the 50deg as shown in one of your examples? If so, and the cycle worked with that angle, then its definitely not 16 Series standard that's in place.
    Post a bit more of your program.
    Regards,
    Bill
  2. #14
    May 2007
    Quote Originally Posted by fordav11 View Post
    when it wasn't working did you check parameters 0109, 0723, 0724, 0725, and 0726.
    And then after when it was powered off/on did you check the same parameters again?
    If not then you need to do that first and you might find something is different......
    Working Friday. I'll see if it happens again. I know the job I'll be setting up has a thread. I couldn't remember the parameters you had told me to check. I'll write them down this time.
  3. #15
    May 2007
    Quote Originally Posted by angelw View Post
    Regards,
    Bill
    Oops. Just saw your post. Yes it is still a one line G76. I'll try to remember and write the threading operations down tomorrow night and post both later for you. Pretty sure the angle wasn't used in one of the programs I tested, but a P2 was used in at least one. If I remember correctly, one of them used a decimal with the K value, one didn't.
  4. #16
    May 2007
    Ran my new program tonight up to the thread cycle. Same alarm. At least I knew this time that I probably would have to restart the machine in order to clear out the problem. What I did was make a change...try it. If it still alarmed, I shut down, restarted and tried again. If it still alarmed, I made another change and went through the same process again.
    I now know what part of my threading cycle is causing the problem...but not why. I always program a compound infeed. What I found was that you can not use an A-word. I was running an older Daewoo Puma (8 something, I think). Tried with and without a decimal. Once you use the A-word, the lathe has to be shut down before it will run the threading cycle.
    It seems to me that the A-word is changing a parameter that the control doesn't like. There are no manuals for this lathe, but the owner does have an OT Fanuc Operator's Manual. I didn't look tonight, but I'm fairly certain I saw the A-word used in the example it gave. Maybe the manual isn't the right one for this control. I only have one Fanuc OT manual at my regular job, and it isn't like this one. This one has Mate in the title.
    I program a Hitach Seiki with a Seicos control that uses the A-word in its 1-block G76 call. Haven't programmed our older Mori Seik SL-25 in a few years, but quite certain it also allows the use of an A-word. I think it is a T-6 control. I was under the impression that the single block G76 always allowed an A-word. At least from the few manuals I have seen.
    Also discovered another problem with the threading cycle tonight. The re-thread makes 3 passes even though the K and D have equal values. I assume this is controlled by a parameter. Anyone know what it is? Would like to change it to one pass. I appreciate the efforts of you gentlemen trying to help discover the problem. Thanks.
    EDIT: I can post examples of my threading cycles if you still need them. Figured you wouldn't given that I now know what is causing the alarm.
  • #17
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    A is used in all single line G76 versions. But on some controllers you can not use just any old number. Some will only accept 80°, 60°, 55°, 30°, 29°, and 0°
    That's probably the cause of your alarm.
    The number of finish passes is set by parameter number 5142.
    The machine will do 1 pass anyway, so if you want 3 finish passes set 5142 to 2
  • #18
    May 2007
    These are the same values used by the 2-block call. I haven't read where the 1-block call limits the choices, but my exposure to machines using 1-block calls is very limited. I'll give one of them a shot next time. Will also look at parameter 5142. Thanks.
  • Page 2 of 2 FirstFirst 12
    1. Problem- Machine quit working
      By rnponti in forum Gecko Drives
      Last Post: 07-10-2011, 07:54 AM
    2. Need Help!- Xylotex Board quit working !
      By kel1 in forum Xylotex
      Last Post: 04-30-2010, 04:06 PM
    3. Problem- Syil Spindle has quit working
      By marco928 in forum Syil Products
      Last Post: 03-16-2010, 02:01 AM
    4. Tool changer quit working
      By acrodave in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-21-2010, 03:05 PM
    5. ncEdit quit working
      By Cameo in forum Surfcam
      Last Post: 06-28-2007, 01:47 PM
