I have a fanuc series 15 and my z-axis servo is getting hot even when not in use (when in idle machine on) The other Axis servos are cool to the touch. Is this normal and if not what could be the problem?This is a Shoda cnc Router With Mitsubishi plc contollers.We had to change one of the servo contollers about 2 years ago with a rebuilt one. |
| Usually means there is resistance even at rest and the motor is either underpowered or there is mechanical friction, in the case of a Z axis on a mill, usually often the counterbalance is not working or ineffective, depending on the method you have. Al.
| Overheating? yeah thats possible with a bad bearing. It's possible that the servo got stressed at some point in its life. Part of my regular maintenance is to check servos. Make sure that they are not getting damaged. I also make sure that everything is moving as it should and not overload or overheat the motor. What type motor is it? Mine was rebuilt twice and the 2nd time it was certified. Mine is a FANUC 3S. I also have the 6S and 8S types to that I could use if I wanted. They're so expensive that I bought two. |
| Yeah, it's great to have a machine last at least a decade without major failure. The 20S is a good spindle servo motor. The 3S and 6S seems to be the most popular of the S spindle servos. I never see to many of the others. I just don't have the greatest information on them. |
| I changed servo and it helped. The servo is not heating up as quickly but is still getting warm during idle time. I',m wondering if my pnumatic balencer is not set right. When I power down the Z-Axis travels up and I'm thinking it should not move at all, down or up. Is it trying to push against the balancer when in idle and that is what is overworking the servo? |
| If the counterbalance is still active as when the servo is powered then it is pointing to wrong adjustment, ideally there should be virtually no back feeding when the motor is inactive. Al.
#10
| Need Help!- 253 ELECTRONICS OVERHEAT | Machineit | Haas Mills | 5 | 08-17-2011 02:55 PM |
| scr dcm overheat??? | protrxrptr17 | Fanuc | 1 | 09-02-2009 09:10 AM |
| Need Help!- Servo Motor OverHeat | Shvenk | Servo Motors and Drives | 0 | 07-03-2009 01:25 PM |
| Need Help!- X Axis Servo Motor Overheat | mtgpaul | Colchester Tornado lathes | 5 | 10-17-2008 07:37 PM |
| 702 DC motor overheat | Rocksalt | Fanuc | 6 | 09-29-2006 05:13 AM |
