Old 09-27-2011, 02:52 PM
aaiusa is on a distinguished road
Unhappy sv023 error overheat!
I have a Shoda cnc router with Fanuc15fm controller.The machine has Mitsubishi plc controls. I can run a program several times with out any problems. Then sometimes I get an error SV023. This only happens sometimes and when it does the spindle head goes up and the program stops. I can reset the alarm and finish the program if I don't get the alarm again. The Z-servo is hot even when being idle. The other servos don't get hot when not being used. Is this normal? I have another sevo but I don't want to have the same problem if I replace it.Does anyone have a suggestion?
Need Help!- SV023 Z sv overload Fanuc 10M vladimir1409 Fanuc 1 06-23-2011 06:42 AM
SV023 Alarm on 10T control Radius Fanuc 23 03-23-2011 07:11 PM
Need Help!- Error 414 Z axis error detect- servo alarm andywids Fanuc 0 07-09-2009 10:33 AM
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
SV023 Alarm on control boot up - Puma 6 with 10T Radius Daewoo/Doosan 3 08-30-2007 10:39 PM
