Old 09-27-2011, 12:22 AM
laka is on a distinguished road
Fanuc 0-M wont change tools (1989 Cincinnati Sabre)
I posted this in the Cinci forum, but may have better luck here?:
I've just aquired a Sabre 750 w/Fanuc 0-M and am having some trouble with the toolchanges. Previous owner thought the TC was broken, but I can jog it fine to the spindle and index to a new position etc. Problem is when I try a M06 command either in a program or MDI, I get alarm #59 or #78. It seems like the macro program for toolchange is missing? I'm fairly new to Fanuc, from what I've read on CNC Zone their should be a program in the O9000 range that is the macro for toolchanging but I cannot seem to find anything like that on the control.
I read about some of the toolchange macro M-codes (M19 - M25ish) and the only one that works in MDI is M19.
Currently when I look in the list of programs there are no programs in the O9000 + range.
I have a feeling I may need to find a macro program from a similar machine?
I am a little lost at the moment so any help or ideas appreciated. Thanks!
Old 09-27-2011, 08:14 AM
MIYANO vs FANUC is on a distinguished road
You should be able to MDI a G90G28Z0; to send the Z up for a tool change. Then a M19 for spindle orientation. Call up a tool number and a M6 command.
I swear that I wasn't bidding on that nasty old CNC... I was only swatting flies.
1989 Sabre 750 w/Fanuc 0-M won't change tools laka Cincinnati CNC 0 09-26-2011 12:14 AM
1989 Sabre 750 Fanuc OM Power requirements laka Cincinnati CNC 1 09-24-2011 08:49 PM
VMC20 Air Valve Clicking, wont change tools or startup spindle interrmittantly??? WeTDrEaM Fadal 4 08-28-2011 10:37 PM
Cincinnati Sabre 500 leggetmachine General Metal Working Machines 8 05-15-2011 11:14 PM
1989 Cincinnati Sabre 750 Acramatic 850 pinionblack Cincinnati CNC 0 07-28-2010 09:30 AM
