Old 09-26-2011, 01:31 PM
rhadoo_io is on a distinguished road
Fanuc 21i-MB DNC
I have been trying for the last two weeks to find a way to DNC on a Kira machine with Fanuc 21i-MB control,it has no RMT or TAPE switch nor does DNC appear anywhere in the menu.I cannot DNC from card as no such option is presented so I have built a full pinout cable and have been able to transfer programs both ways but i'm unable to activate RMT mode to drip-feed.
Is there a way to enable RMT through parameters?or anyway to dnc?
Please help!
Old 09-27-2011, 05:02 AM
fordav11's Avatar
fordav11 is on a distinguished road
Try searching for DNC or Drip Feed on these forums and read all the posts.
Another option is to use some third party software.....
http://www.cnczone.com/forums/gibbsc..._cnc_mill.html
But why drip feed? Can't you just put the program in memory and run it?
Old 09-27-2011, 05:41 AM
cncwapner is on a distinguished road
It will be a machine bulder keep relay. You should have a option button on
the control that takes you to a different screen that the machine builder adds to the fanuc. On mori's, it would have ATC recovery and APC recovery.
Old 09-27-2011, 06:56 AM
DNC
I can't just run the program as it is several times bigger than the memory
i figured out that this is related to the machine builder and after reading through the forums i found parameter G127.5 which should be what i am looking for.
The problem is that i don't know if i can enable this as a PMC parameter or through the ladder....Does anyone know how can this be done?
Thank you for your help!
Old 09-27-2011, 09:14 AM
Does the control have a key down at the bottom right that says option?
Old 09-27-2011, 10:11 AM
No...
Old 09-27-2011, 12:40 PM
yours_prabhat is on a distinguished road
Set the parameter umber 101 #7 111#7 or 121 #7 to 1 this parameter will improve the Memory Efficiency. (These are parameters NFD)
Old 09-28-2011, 03:03 PM
EECENOD is on a distinguished road
what type control
Originally Posted by rhadoo_io View Post
what type control
Old 09-29-2011, 03:52 AM
fordav11's Avatar
erm.... it states in the first post.... Fanuc 21i-M Model B
anyway, you should be able to change the PMC parameter. In MDI turn on Parameter Write Enable first.
Go to PARAM then PMC then depending on control specifics there should be something like PMCPRM. Press that then go to D-Data then G-DATA. cursor down to G127 then across to bit 5.
Bit 5 is 00x00000 (marked with X). It will probably be 0 so make it 1 or if it's 1 make it 0.
since you are dealing with machine-specific settings you are mostly on your own as to whether it works or not. If there's no change put it back to whatever it was and look for more info.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
Need Help!- Difference between Fanuc 0i-MC and Fanuc 0i-MD humak16 Fanuc 12 12-29-2011 10:49 PM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
