Old 09-24-2011, 09:55 PM
charger19690 is on a distinguished road
Fanuc OMc M-Code and Indexer
So I have been reading a bit and wondering if I can get a little detailed answer.
I have an 1990 Kia KV40A with a Fanuc OMc control bought at auction.
I bought an old Haas Indexer with a Control Box. Pretty confident that I can wire it up to the control box reading the Haas Literature, but my problem lies with finding an M code.
My buddy in his shop has 4 of these machines, 3 which were wired for signal driven indexers which use I believe M71 as an index code.
I paged through my "Ladder" (which I don't completely understand) looking for an M71 code. No luck. I found everything from M1 to M90 and M91 (Door open and close). At the control when I type in an M71 in MDI, the cycle start light comes on and waits.
My questions is, could these mean this is a valid M-code on this control and is waiting for the MFin relay to fire?
Overall, I am wondering how to track down this particular code, or page through the Ladder and look for something different? Or should I just through caution to the wind and use find the Door Open relay M-Code that isn't being used. (By the way, this machine is a semi-open faced machine and has no automatic doors. It also has Pallet clamp and Unclamp M-Codes in the ladder???
I was thinking about just hitting the M71 in MDI and tracking down the MFin relay and see what happens, but I figured I would see if there was any direction here first.
Mike in MN
www.cncbasics.com www.mastercamforum.com
Need Help!- basic indexer on cincinnattii dart with 21i fanuc control sixa1 Fanuc 0 05-07-2011 05:00 PM
Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code nessei Fanuc 4 03-29-2011 08:39 AM
Converting Fanuc G code to Seimens 840D G code Jasbinder Siemens Sinumerik CNC controls 2 02-20-2011 10:02 AM
fanuc om indexer joachim Fanuc 2 10-27-2009 05:06 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
