Old 09-22-2011, 02:51 PM
hrhoward is on a distinguished road
O-TT 4n1 Alarms
Hello,
I have a Star KNC-32 with a Fanuc O-TT control.
It throws a 4n1 (EXCESSIVE POSITION ERROR DURING MOVE) error anytime I try and move the X1, Y1, or Z1 axis in rapid. Each of these axis will jerk then quit.
Any help would be appreciated.
Thanks,
H. Howard
Old 09-24-2011, 07:39 AM
stevo1 is on a distinguished road
If you slow your rapid override done or try a feedrate move does it still do it. I am not an expert in servos but it sounds like you need some servo parameter adjustments.
Stevo
Old 10-04-2011, 03:01 PM
If I set the rapid override to 1 it is fine. It doesn't happen when using feedrate.
Old 10-04-2011, 04:02 PM
Then I would suspect as I stated above. Your servos probably need some tweeking with the gain or something along those lines.
I sent an email with the manuals attached per your PM. I zipped them as they are 8mb total so let me know if you receive them or not.
Stevo
Need Help!- Alarms sjj Mazak, Mitsubishi, Mazatrol 1 09-02-2009 08:16 AM
T-32 Alarms mbpp Mazak, Mitsubishi, Mazatrol 4 12-13-2008 08:42 PM
Problem- M Plus Alarms MJMark Mazak, Mitsubishi, Mazatrol 3 07-29-2008 03:39 PM
ALARMS 250 and 251 Geof Haas Lathes 5 02-15-2008 09:32 AM
