After deleting the parameters on the mv55 w/fanuc om and having to call the Mori dealer to get them, I decided it would be a good idea to back them up on a PC. With the instructions I found in a thread on here I was able to back this machine up without any problem. I am now trying to back up some other machines, and have a few questions about them I'm hopeing someone here can answer. First is a 10m. The operator manual tells you how to punch the parameters on this one. On the screen you can choose which parameters to punch, NC, Pitch, All, or PMC. I can send the NC and the Pitch parameters to the PC fine. If I choose All, I still just get the NC and Pitch. If I choose PMC all I get at the PC is a %. Can you not send these the same way? Is there anything else that needs to be recorded on this one? Next are a couple of lathes. One is a 6t and the other is a 6tb. Can you punch the parameters on these or should I just write them down? Anything else that needs to be recorded on these? Thanks |
| There is a set of info that machine maintenance techs call "System Configurations." You could save these as well if desired. As far as the 6T controls are concerned, please let me know if you figure it out. We have some of those dinosaurs, too. I tried every way under the sun to punch-out the parameters... but no luck. I would THINK it should be possible... but who knows what they were thinking 100 years ago. I called GE & asked about this control once. The guy literally laughed out loud. He said, "we didn't even own Fanuc that long ago." |
| First, you cannot save the pmc params to a computer on FS 6,10,11,12. You have to manually record them. You also have to back up programs (watch out for hidden ones), macro vars, offsets. Don't worry about the ladder on any Fanuc control. |
1. Select the parameter page 2. Select Edit Mode 3. Get the external device (PC) software ready to receive 4. At the control type P-9999 then press the PUNCH button 5. Parameters will now be output to the external device. Regards, Bill |
| Ok, thanks guys. I will get them recorded. Think I will get a few SD-cards for the digital camera (one for each machine), and take screenshots of all the settings. memoryman, How would I find any hidden programs and macros that I should back up? |
| I would like to know too. I'm workin on makin up my parameter list for when my 6M-B2 is finished. I have found my A06B-0641-B011 servos in the pile I received a couple few months ago. I lost pretty much everything when I pulled the control from my Monarch V45 some years ago. I think i even had the M/M board. |
| for 10m there's a parameter/pmc backup procedure here.... Fanuc 10 Fanuc 11 Memory Backup Procedures to know if you have hidden macros just change parameter 3202 bit-0 to 0 for programs 8000-8999 and parameter 3202 bit-4 to 0 for programs 9000-9999 (i.e 3202 should be xxx0xxx0 the x's are ignored here, the 0's are the bits that should be noted) to show them and check the program directory, or call them into memory one by one and have a look. Once the parameter is changed to allow reading/editing you can just punch them out like any other normal program. If you don't see any 8xxx or 9xxx numbered programs you don't have any secret macros |
| Regards, Bill |
#10
| here is a more complete list CONTROL PROGRAM #s PARAM BIT # PROTECT UN-PROTECT 0 9000 10 4 one zero 6 9000 318 7 one zero 10 9000 2201 0 one zero 11 9000 2201 0 one zero 12 9000 2201 0 one zero 15 9000 2201 0 one zero 16/18 9000 3202 4 one zero 6 8000 319 7 one zero 10 8000 11 0 one zero 11 8000 11 0 one zero 12 8000 11 0 one zero 15 8000 11 0 one zero 16/18 8000 3202 0 one zero |
| Backing Up Parameters? (OSP700L) | H234 | Okuma | 11 | 04-14-2012 02:28 AM |
| FANUC 18iT, backing up the machine parameters | MRPM | Fanuc | 2 | 04-02-2011 06:31 AM |
| Need Help!- Backing up Parameters | wganders | Daewoo/Doosan | 0 | 01-07-2010 01:18 PM |
| backing up parameters | robinhood2b | Bridgeport and Hardinge Mills | 2 | 09-30-2009 09:31 AM |
| Backing up Control Parameters & Settings on VF3 1998 | Rocko1 | Haas Mills | 3 | 02-03-2009 10:40 AM |
