Old 09-19-2011, 04:38 AM
chatree_w is on a distinguished road
FANUC O-T alarm 930 cpu interrupt
when I turn on the machine about five minutes.
machine alarm 930 cpu interrupt
I replace new batterry machin alarm the same
Old 09-19-2011, 07:23 AM
cnc2149 is on a distinguished road
The 930 CPU Interrupt often occurs when there's a disruption to the 5V logic supply. This is usually due to electrical noise in the machine or in the electrical panel. FANUC misleads you in the manual by suggesting replacement of the master board. This rarely solves the problem. This fault is almost always caused by problems in the grounding or electrical arc suppression of AC and DC devices. Often, the problem will not occur if you leave the machine in Estop after powering up. Once you take it out of Estop, hydraulics, etc come on and that's when the problem usually occurs.
Searching and correcting electrical noise problems can painstaking and detailed. It is useful to have a storage scope on the 5V test pin on the CNC Masterboard and set the trigger level around 4V. If you observe a disruption while bringing up and dropping out magnetics, this is a problem. You'll have to isolate and figure out which devices (relays, solenoids, contactors) are causing the problem.
The coolant system seems to be the most prevalant cause of many of these that I've seen. One must carefully check the suppression of DC relays (reverse biased diode across the coil) and also AC contactors (RC network across the coil and RC networks across the contacts).
Old 12-15-2011, 03:29 AM
Camfather is on a distinguished road
I have a similar problem, but mine seems to only be when it's cold out, starts up with a 930 alarm, after several tries, machine will power up, but this is a new install of an older machine running through a phase converter.
Old 12-18-2011, 09:50 AM
rai rai is offline
rai is on a distinguished road
I had faced the same problem CPU interupt 930 error in my machine equipped with fanuc OT-C. My problem got solved after replacement of the memory card.
Old 12-30-2011, 11:37 AM
tmbruno28 is on a distinguished road
memory card ?? are you sure
Normally, on the FS0C, the problem comes always from the main board ......
Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? blakemachine Fanuc 1 11-11-2010 12:42 PM
No Interrupt alarm on 2001 Haas Mini Mill? JasonR Haas Mills 5 08-01-2010 01:06 AM
Need Help!- No Interrupt on vf2 2000 tecko Haas Mills 3 01-25-2008 06:59 PM
E-stop, Interrupt The 110v Ac Or 28v Dc? Mr.Chips General Electronics Discussion 1 02-06-2007 08:49 AM
inputio interrupt driven? howling60 CamSoft Products 2 02-10-2006 01:38 PM
