Results 1 to 4 of 4
Thread: Churchhill Grinder with fanuc series Oi-TC controller
    Aug 2008
    Nigeria
    Please help to solve this problem.
    Grinding is not smooth & noisy.
    I think the following setup is not OK.
    Wheel width = 80mm
    Passes = 10
    Infeed value = -0.050mm
    Dwell value = 01 sec
    Aug 2008
    Nigeria
    Still looking for help.
    I doubt if the Infeed value (-0.050 is crrect)
    Also note that the the X & Z value does not correspond with the reference.
    Any help will be appreciated.
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    are you grinding OD or ID? what is the rpm of your wheel and part?
    what do you mean when you say the values do not correspond with the reference? which reference and which X/Z values?
    0.025 is a better in-feed value per rev but grinding isn't very difficult or complex usually so I don't think it's that critical if the feed is only another 0.025 more if your part is not thin
    I worked a Churchhill grinder when I was an apprentice 25 years ago.
    maybe your machine has maintenance issues? how old is it and is it in good condition?
    Aug 2008
    Nigeria
    JOB SETUP
    ............................ Theory(in manual),,ON SCREEN DISPLAY...........ACTUAL
    WORKHEAD SPEED..........60rpm.................60rpm
    GRINDING FEED RAT.......1500mm/min..........1000mm/min
    WHEEL WIDTH...............80mm...................80mm
    PASSES.......................10,,,,,,,,,,,,,,,,,,,,,,,80
    INFEED VALUE...............0.010,,,,,,,,,,,,,,,,,-0.050
    DWELL VALUE-----------01 SEC,,,,,,,,,,,,,,,,01 SEC
    X Home position............610.558,,,,,,,,,,,,,,,550.000,,,,,,,,,,,,,,,,,,,,,,600.000
    Z Home position............1759.55,,,,,,,,,,,,,,-350.000,,,,,,,,,,,,,,,,,,,,,,2982.833
    DWELL LEFT.................OFF.....................ON
    DWELL RIGHT...............OFF.....................ON
    INFEED LEFT................OFF.....................ON
    INFEED RIGHT..............OFF.....................ON
    The on the screen display on the third colum is what I think is not correct.
    The actual home position is in colum four.
    FORDAV11 THANKS FOR YOUR HELP.
  1. Need Help!- GE Fanuc Series OM Controller
    By otto.wilcken in forum Fanuc
    Last Post: 03-13-2012, 09:27 PM
  2. fanuc series 31i model A5 controller
    By yaman in forum Fanuc
    Last Post: 02-14-2011, 03:19 PM
  3. Replies: 2
    Last Post: 01-14-2011, 02:51 AM
  4. Fanuc 160i-M Series Controller
    By kevin08 in forum Fanuc
    Last Post: 07-11-2008, 10:05 AM
  5. GN6 Series Fanuc Controller
    By CBMach in forum Fanuc
    Last Post: 08-15-2005, 08:46 PM
