Old 09-10-2011, 02:04 PM
JOC JOC is offline
JOC is on a distinguished road
Zaxis tach gen disconnect alarm
How do I determine if my problem is with the tach gen or servo board? All connections are solid. Board is Fanuc A20b 1001 0770 04B servo is AC Fanuc "red cap". Are schematics available? Any test I can perform w/o-scope etc?
Old 09-10-2011, 03:16 PM
Al_The_Man's Avatar
The Red Cap, (AC servo's) do not usually use a DC tach in the sense the DC ones did, at least I have never come across a AC motor that uses a tach?
The encoder usually performs all position and commutation duties.
Old 09-10-2011, 06:22 PM
JOC JOC is offline
Hi Al,
Thanks for the reply. There is an encoder on the end of the servo. On the screen it is displayed as tach gen. disconnect. however when X comes up it refers to a pulsecoder disconnect?
Old 09-10-2011, 06:59 PM
Al_The_Man's Avatar
It is more likely you have a problem either with the encoder or the cable.
First measure the continuity through to each end of the cable.
Old 09-11-2011, 08:19 AM
JOC JOC is offline
Had checked all wiring and connectors. Continuity checked OK. Do you know of any checks I can perform to prove out the encoder?
Need Help!- 416 X-axis disconnect alarm alexbelen7 Fanuc 4 04-18-2010 06:47 PM
Need Help!- Pulse Coder Disconnect alarm asctm Servo Motors and Drives 0 01-30-2009 09:45 PM
y axis disconnect alarm kirby Fanuc 8 03-14-2008 04:27 PM
Tachogenerator disconnect alarm on 10T Crashmaster Fanuc 5 10-09-2007 03:35 PM
Fanuc 21-GA_416 Alarm-Axis Disconnect lasermike Machine Problems, Solutions , Wireless DNC, serial port 0 03-10-2005 12:49 AM
