Old 09-08-2011, 06:59 PM
waybriks is on a distinguished road
Unhappy hardinge cobra 42 fanuc 21i control
Machine is new has 2 hours runtime on it. I can't get programs in or out using the card / adapter or computer. I have looked the parameters over and all seem good. it acts like nothing is there computer or card. I have the cable wire 9 pin to a 25 pin 2 to 2 3 to 3 5 to 7 jumper on 25 pin end 6,8,20 cable works on all my other machines. Anyone out there with any clues on this one? What could it be?
Old 09-08-2011, 09:11 PM
dcoupar's Avatar
Have you changed the I/O device on the settings page to 4 for the card or 0 (or 1) for the RS232 port?
Old 09-09-2011, 04:56 AM
hardinge cobra 42
yes, I changed it when using the card and computer. The book says for the card use 4 in some places and 3 in others. Neither works. When using the computer use 0 no luck with it either. It has to be something easy and stupid I'm doing..
KW
Old 09-09-2011, 08:30 AM
dcoupar's Avatar
Are all your other machines Fanucs?
Does OUTPUT blink in the lower right of the CRT when you PUNCH from the machine?
You should have pins 4 and 5 jumped together on the CNC end also.
If all else fails, go to Radio Shack or Fry's and get a ~$14 RS232 tester to check for activity on pins 2 and 3.
Old 09-09-2011, 08:53 AM
othgers are fanucs cable works on all of them. I do have 4 & 5 jumped on the cnc end. output light blinks. I'm going for the tester. I will let you know the next developement
thanks
KW
Old 09-12-2011, 12:41 PM
got it running, problem was in the parameters that are common to all output / input devices.
hardinge conquest 42 VS cobra 42 mls Hardinge Lathes 5 09-07-2010 04:42 PM
Hardinge Cobra 51 & Fanuc 21i-T Question CNCBahamas CNCzone Club House 3 07-04-2010 04:37 PM
Hardinge cobra 65 collet closer vsmvj General Metal Working Machines 0 07-30-2009 09:13 AM
Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual samu Bridgeport and Hardinge Mills 5 09-02-2008 08:36 AM
Parameters on Cobra 42 Hardinge Niall Bridgeport and Hardinge Mills 0 07-16-2004 04:38 AM
