Old 09-07-2011, 09:13 AM
Datech is on a distinguished road
Funuc oi-tc Alarm #064
064 SHAPE PROGRAM NOT MONOTONOUSLY. What is this meant?
G00 Z.1
X4.51
G71 U0400
G71 P100 Q200 U0100 W0 F.01
N100 G00 X4.224
G01 Z0 F.005
G03 X4.275 Z-.025 R.025 F.002
G01 X4.2725 Z-3.7114 F.004
X4.4934 Z-3.9026
G03 X4.5 Z-3.9151 R.025 F.002
N200 G01 Z-4.1 F.004
G70 P100 Q200
What missing in the program?
Old 09-07-2011, 09:21 AM
hitachibos is on a distinguished road
what is the X and Z position just before you call this routine?
it should be the same X as end point X4.5 and the Z off the face .050 or .1
Old 09-07-2011, 09:37 AM
dcoupar's Avatar
G71 U0400
N100 G00 X4.224 <----- Initial X --- try adding W0 to this block
G01 Z0 F.005
G03 X4.275 Z-.025 R.025 F.002 <----- Increasing X
G01 X4.2725 Z-3.7114 F.004 <----- Decreasing X - not allowed in TYPE I cycle
X4.4934 Z-3.9026 <----- Increasing X
G03 X4.5 Z-3.9151 R.025 F.002 <----- Increasing X
G70 P100 Q200
If the program above is the correct shape, you can try adding a W0 to N100 to specify a TYPE II (non monotonous) cycle. If your machine has the option, you shouldn't get the alarm.
Old 09-07-2011, 09:51 AM
dcoupar, add w0 to n100 solved the problem. Thank you for your help.
MV40 Funuc 10M APC awryheart Mori Mills 0 11-08-2010 05:32 AM
how to set clock on Funuc 21I-mb bigtown Fanuc 4 10-12-2009 09:08 PM
sending large program to Funuc 21I-mb bigtown Fanuc 7 09-22-2009 04:49 PM
What controller do I use, is FUNUC defaut? skipper SolidCam 5 04-06-2009 07:04 AM
Turrent Change on a Funuc oi-TB metalmansteve Fanuc 4 11-02-2006 04:17 AM
