Hello, I am having a problem sending Z axis home after we set up this machine in my shop. We had to remove the servo (Z axis) to get the machine into my shop. Now I can't get Z axis to reference home position. I tried fooling the soft limit in parameter 1320. I also tried P cancel as well. No luck. If anyone has a solution, I appreciate it. Thanks, Picman |
| whats it do ? does it go in the home direction and slow down? then alarm out with hard OT? does it not get to slow down and just alarms out with a soft over travel? if soft over travel then open up that 1320 parameter if it slows down then hard overtravel then you want to find "Grid shift" parameter and start by cutting it in half. if that does it then you want to get it right by useing a known height block on the table. bringing down the head till block just slides under. then write down machine position for Z and send machine back home. do the math between the two machine positions and adjust the "Grid shift" parameter as needed to give you the factory stated travel between table and spindle nose. |
| sounds like it reads the slow down but grid shift is too large and it hits hard over travel before it reaches the grid amount. if you can get this set to factory distance from table up you should be ok but if you just fudge the numbers you will have tool change issue as well. |
| GE Fanuc & FANUC proprietary posts | CNCadmin | Fanuc | 44 | 01-05-2012 08:54 AM |
| FANUC & GE FANUC Repairs | RRL | Product Announcements & Manufacturer News | 1 | 04-17-2011 11:50 AM |
| can fanuc ac digital servo amplifiers be run by a controller other than fanuc? | js412000 | Servo Motors and Drives | 5 | 03-09-2011 09:11 AM |
| Fanuc & GE Fanuc Repairs | RRL | Product Announcements & Manufacturer News | 0 | 10-01-2008 12:42 PM |
