Ok, so I went to hook up my Chip Conveyor to the HT20 Hitachi lathe with the fanuc 10t control. I got the three phase wiring hooked up to the internal relays on the control box of the conv. up. But then there is a Blue and Orange wire that went to some sort of contact, but when testing what these wires do I accedently touched them together, and got a small spark. After seeing where these wires go, I found out that they go to a connector on a board called Kchp. Anyways now I am getting SV013 alarms for X and Z axis. I have tried reseting the breakers on the servo drives, but no luck on correcting the alarm. Where Else Can I look? |
| Ok after further investigation, I found that the distribution board had some burned traces, see photos. So I had a spare board and installed it, with the conveyer totally disconected, and am still getting the same alarms!! WHen I hit the reset button, the Prdy led on the servo drives lights up for a second then turns off, and has the same alarm. Where shall I look next? |
| I will dig the HT20 manual out and see what I can see! Al.
| Can't seem to find that Dis board in the prints? Did you repair the trace and checked all fuses? Al.
| Shorted motor? | richlandrick | Automation Technology Products | 3 | 04-17-2011 11:17 AM |
| Fanuc 21-tb alarms | Hlynur | Fanuc | 7 | 03-31-2010 12:08 AM |
| Need Help!- SV013 Alarm Fanuc 11M | kalawa | Fanuc | 19 | 12-02-2009 04:46 AM |
| Fanuc 400 alarms and other | alphatad | Fanuc | 28 | 02-04-2008 08:32 AM |
| Fanuc 6MB 401 and 410 alarms | john braks | Fanuc | 0 | 02-24-2006 12:45 AM |
