Old 09-04-2011, 03:45 AM
fordav11's Avatar
fordav11 is on a distinguished road
Check for "Alarm 73 - PROGRAM NUMBER ALREADY IN USE" not active?
on my machine (MSG-500 Fanuc 18i) if I read in a program that has the same O-number as one already in the memory that program is overwritten with the new program. Is there a parameter to stop/enable the overwriting and instead generate an alarm? I checked the parameter manual but can't see anything? I remember on Fanuc 0/10/11/12/15/16 that alarm 73 will come up "PROGRAM NUMBER ALREADY IN USE". On the newer 18i series it just overwrites the program! argghh! :/
Old 09-04-2011, 09:36 AM
viorel26's Avatar
viorel26 is on a distinguished road
Param. 3201 bit 2
Old 09-04-2011, 11:20 AM
dcoupar's Avatar
#3201 bit 2 - See attached
Oops... Sorry Viorel26, I didn't see your post. I should have 1st cup of coffee BEFORE sitting down at PC.
Name:	18i Program Load alarm 073.jpg‎
Old 09-04-2011, 04:22 PM
fordav11's Avatar
ah yes. thanks!! not sure how I missed that
SOLVED - "Alarm: 151 - TOOL GROUP NUMBER NOT FOUND" BrianSP Fanuc 0 09-13-2010 01:36 PM
"jword given for arc in xz plane line number xxx" ??? HankMcSpank G-Code Programing 5 05-11-2009 07:28 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" rfdoyle Bridgeport and Hardinge Mills 4 10-08-2007 03:35 PM
"tool slot number too large" code dave6 Mach Mill 1 10-10-2006 05:57 PM
