Old 09-02-2011, 01:40 AM
Swemill is on a distinguished road
Fanuc 10M tower lights
On my Kitamura Mycenter with Fanuc 10M i have a tower / warning light with red green and yellow lights. The red light works with alarms as it's used to do on cnc machines but when works the yellow light?
I have seen this light sometimes "spin" (for only some seconds) when the machine is on and stands still. Can't find any info on this and the screen tells me nothing....
The green light have also never been lightened / spinning as thought it should when i run a program!?
Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
Yes, they are old..... but i still like them!
Old 09-02-2011, 03:29 AM
fordav11's Avatar
fordav11 is on a distinguished road
The traffic lights are usually optional extras and simply wired into some connectors that are powered at specific times.
In normal operation red is for alarm, orange is program end (i.e. M30) or M00 waiting. Green should be on when the cycle runs. Since the lights are on the machine it should be configured and working. If they don't work as expected perhaps the globes are bad?
Problem- Lights out... jpastor1234 Haas Mills 3 08-16-2010 10:22 AM
X3/X4 Z tower bending compensation for only 3KG neilw20 Syil Products 9 07-22-2010 04:37 PM
Problem- TNC 145 cs Lights On mjp Bridgeport and Hardinge Mills 6 01-18-2009 08:25 PM
Help with robot-tower design cnczoner Mechanical Calculations/Engineering Design 6 11-22-2008 08:26 PM
Z-axis - mounting rails on spindle side, rather than tower side guru_florida Linear and Rotary Motion 7 01-31-2008 06:54 PM
