Does anybody know if I can update my work offset using a G-code in my program? What I have is a boring mill with an 18i-MB control with a quill controlled as the fifth axis(W) parallel to the Z axis. I know Toshiba machines with Tosnuc controls use G173 and from what I understand is that this will change the fixture offset to compensate for the amount that W axis quill is sticking out. So if G173 W-7.000" is programmed, the work offset will be compensated so that the Z axis will know that the quill is protuding 7.0". |
| Fanuc uses G10 for offset modification. G10 G90 L2 P1 W-7. would set G54 W-7. L2 Pn can set G54 (P1) to G59 (P6) G10 G90 L20 P1 W-7. would set G54.1 P1 W-7. L20 Pn can set G54.1 P1 to G54.1 P48 You can also use G10 G91 to increment the value. |
| Need Help!- No Work offset | Jelle_b_k | G-Code Programing | 1 | 06-16-2011 01:22 PM |
| Need Help!- work offset | Claude Boudreau | BobCad-Cam | 3 | 11-22-2009 05:41 PM |
| Need Help!- DYNAPATH 20, WHEN E-CODE IS ENTERED, POSITION DISPLAY DOES NOT UPDATE. | WEBBERS_14 | General Metal Working Machines | 0 | 08-28-2008 10:09 AM |
| Resetting the default Work offset code. | RdHawg | Fanuc | 8 | 01-23-2008 06:24 PM |
| Homemade machine update - a work in progress | Chris D | CNCzone Club House | 22 | 01-14-2008 12:02 PM |
