Old 08-27-2011, 07:49 AM
WCC123 is on a distinguished road
Help with FANUC 18T "overload" light
We are funning a FEMCO HL-55S CNC lathe with a FANUC 18T control. This morning we fired up the machine and went to do a skim cut on a part. About halfway through the skim cut the machine stopped and the red overload light is on. We don't have a clue how to reset it. Can anyone offer any help or suggestions? Thank you in advance!
Old 08-27-2011, 08:51 AM
Al_The_Man's Avatar
Probably an alarm written in by the OEM.
Look for any re-settable overload trips on any contactors or overload breakers of any kind.
Old 08-27-2011, 09:36 AM
Still Working on it
Thanks Al. We actually tried all that and everything was reset. We have since noticed that initially the FANUC spindle drive had the green LED with two flashing horizontal lines. Now it actually has the red alarm led with a code of 24 instead of the flashing red lines. Any insight on this? Thank you again for your help.
Old 08-27-2011, 09:47 AM
Al_The_Man's Avatar
If that is the Alpha series serial spindle, the AL24 shows serial data loss of transfer?
Check all the cable connectors to the spindle drive and controller.
Sodick A280 "heat stop by overload" rfarleman EDM Machines 4 02-07-2011 10:12 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
New member with a "Fault Light" question. kweitz CNCzone Club House 1 09-05-2009 10:32 AM
"Unnormal" light on HF 47158? Fast01 Benchtop Machines 5 07-22-2009 11:25 AM
Did Anyone hear of "Spectra Light Mill Control"?? CNCNR General Metal Working Machines 2 01-22-2008 05:28 PM
