Old 08-27-2011, 07:39 AM
fordav11's Avatar
fordav11 is on a distinguished road
Tool setting arm error MSG-500 SL-253
Anyone know which parameter holds the reference data for the tool setting arm? There's about 0.020" error compared to where it should be in the geometry when a tool is set manually. Would be nice to re-set the arm so it works right :-)
Thanks.
Old 08-27-2011, 11:05 AM
underthetire is on a distinguished road
It's a STD fanuc parameter. If no one can answer I'll boot up my computer and take a look. Pretty easy thing to fix.
Old 08-28-2011, 05:01 AM
dbstream is on a distinguished road
Nc parameters 5015, 5016 & 5017. refer to MTB parameter list for original settings
Old 08-28-2011, 05:35 AM
fordav11's Avatar
ah yes! I looked up those numbers in the manual and it has a small diagram explaining what they are :-)
5015 is X+ switch
5016 is X- switch
5017 is Z+ switch
5018 is Z- switch
The description is "These parameters are related to the function of input of tool offset value
measured B. They set the distance (with sign) between the measurement reference
position and sensor contact surface."
I missed it before because the description doesn't mention a tool setting arm :-/
Old 08-29-2011, 03:45 PM
bertus.nl is on a distinguished road
HELLO
I Have the same problem with a hitachi seiki ht25 10tf
BUT i can not find the parameters For compensation.
i'm able to find the rest but it stops at 5013 and begins again with 5110!!!
greeting bertus
Old 08-29-2011, 04:21 PM
fordav11's Avatar
Fanuc may have moved the numbers around. you'll probably need a 10-series parameter manual to find it. try checking through the parameters for three 6 or 7 digit numbers with signs and the 4th one a 0.
I'll get my numbers today and post them here.
In the manual they are under "Parameters of Tool Compensation' Possibly labelled XP, XM, ZP, ZM. (the P/M mean plus/minus)
Newbie- TL-1 tool setting in gang tool mode gunsmither Haas Lathes 11 04-19-2011 10:22 AM
Problem- Tool setting Issues eksinger Haas Mills 22 03-21-2011 10:16 PM
Need Help!- Offset and tool setting mtnhntr Mori lathes 3 01-09-2011 08:28 PM
Newbie- ez-trak sx setting parameter error dreammstr6 Bridgeport and Hardinge Mills 3 08-02-2010 04:30 PM
setting the tool data and the tool offsets Michael82 Mazak, Mitsubishi, Mazatrol 6 01-23-2009 01:50 AM
