Old 08-17-2011, 04:25 AM
Gwaihir is on a distinguished road
Using the "FOCAS" set of libraries (FANUC Open CNC API Specifications)
Hello everybody,
First of all, I apologize in advance for my English mistakes.
Do someone know how to use the "FOCAS" set of libraries ?
(Despite the documentation and some researchs on the Internet, I need some help)
I do a professional training and I'm trying to create a little application in C# which uses the fwlib32 library (which is included in FOCAS) to communicate with a FANUC controller Oi-MB.
When I call the function "cnc_delall" to clear the memory of the machine, the machine must be in EDIT mode (if it doesn't be in this mode, the return of the fonction is : "the machine is busy")
To avoid a manual operation on the operator panel, I want to change the mode automatically. That's why I try to use this functions :
cnc_wropnlsgnl (Writes the output signal of software operator's panel.)
cnc_rdopnlsgnl (Reads the output signal image of software operator's panel.)
When I try to read the data, there is no error return, but all the values readed are 0 whatever the mode is.
Is it the function which I need ?
If there is a need, I will give more details.
Thank you in advance for your help.
Regards,
Gwaihir
Tags
fanuc, focas, fwlib32, library
Need Help!- I need to write what file i want to open.... how can i change to the "old" screen? Vegabond Autodesk Software (Autocad, Inventor etc) 10 12-03-2010 06:55 AM
5"-4un Internal Thread Specifications SheldonB Mechanical Calculations/Engineering Design 2 05-12-2007 02:54 AM
"Open Source" Aluminum Extrusion Profiles devers6 DIY-CNC Router Table Machines 17 12-18-2005 05:04 AM
OPEN SOURCE DIY CNC "thing" High Seas DIY-CNC Router Table Machines 45 05-01-2004 12:53 AM
