Old 08-12-2011, 09:17 AM
cybergomer is on a distinguished road
G76 Boring Cycle
Got a bit of a problem. Got a job that has 4 different boring heads, a pair made by Techniks, and a pair made by Kennametal. The only problem is that the cutting edges are oriented 90 deg between the two manufacturers.
Is there a way to program the offset direction (other than changing the parameters) during a fine boring cycle on a Doosan DNM500 with a Fanuc OI-MC control.
Old 08-12-2011, 03:59 PM
dcoupar's Avatar
Parameter 5101 bits 4 and 5 set the orientation angle for G76/G86.
You could use Programmable Parameter Entry (G10L50) to set this parameter.
NOTE: in the example below x=current value of 5101, so write down current value of 5101 before you execute this command. You only want to change bits 4 and 5.
G10L50;
N5101 Rxx11xxxx (SET BITS 4 AND 5 TO 1 FOR Y- SHIFT);
G11;
If 5101 is currently 10000010, and you want to set the shift direction to Y-, you would program
G10L50;
N5101 R10110010;
G11;
Name:	0iM-C Parameter 5101.jpg‎
Old 08-17-2011, 03:25 AM
sinha_nsit is on a distinguished road
Is it not possible to change the holding angle in the spindle?
Need Help!- Maldus 500M Takumi V11A boring cycle jw12 Mazak, Mitsubishi, Mazatrol 4 02-10-2011 06:12 PM
Okuma Boring Cycle flmachctr Okuma 3 12-03-2010 01:23 PM
Problem- canned cycle for boring newbie cinci5 Okuma 4 03-07-2009 04:35 PM
G76 Boring Cycle Gorrell G-Code Programing 0 01-25-2007 03:22 PM
Haas G85 Boring Cycle (canned) DEAN Haas Mills 7 12-08-2003 10:12 AM
