Old 08-12-2011, 08:12 AM
bbqa01 is on a distinguished road
what is the meaning of voltage value in Fanuc Servo motor
Each fanuc servo motor have a specific voltage: 90V, 56 V, 112V, 47 V?
Someone can tell me what is the meaning of these value,
Can be a fanuc servo motor replace with one differents voltage?
Old 08-12-2011, 08:37 AM
Al_The_Man's Avatar
This is the voltage required to operate at the rated torque and rpm, you should not deviate very much from these limits.
Old 08-12-2011, 08:48 AM
Thank you for your reply,
I thing the voltage applied to motor is 200V*1.4 = 280V DC ???,) Because the servo amp use 200V AC input). Current is varies but voltage is always 200- 220vac <=> 280 vdc?
Old 08-12-2011, 09:09 AM
Al_The_Man's Avatar
This is most likely a 3 phase SCR drive across the AC supply. If so the mean level is something lower than the peak.
Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor Bordaco Servo Motors and Drives 4 09-08-2011 05:41 PM
Need Help!- Fanuc-18P No Display!! Pl help Status LED meaning? ledforless Fanuc 2 07-08-2011 09:03 AM
Fanuc DC servo, what voltage? Jonne Fanuc 3 09-21-2007 09:27 AM
Fanuc model 5 motor voltage question Syp Servo Motors and Drives 1 01-23-2006 07:37 PM
servo motor voltage? tpworks Gecko Drives 2 04-17-2004 02:34 AM
