Old 08-10-2011, 07:13 AM
ahmed4040 is on a distinguished road
Fanuc X axis vibration problem
Does anyone know which parameters should be adjusted for Fanuc 0iMC with alpha-i motors when there is a vibration in X axis ?
this vibration appear at the end of X axis stroke (for b both sides)
Old 08-10-2011, 07:49 AM
CNC Viking's Avatar
CNC Viking is on a distinguished road
I think that your X-axis amplifier is singing on its last vers...
Check this thread for different try-and-errors. I solved my problem by changing the amp after some back-and-forth testing such as swapping amps, swapping servo motors, even swapping encoders...
http://www.cnczone.com/forums/mazak_...oud_noice.html
Old 08-10-2011, 01:27 PM
msa msa is offline
msa is on a distinguished road
Hi
tray to ajust the prop gain (KW faktor)
(system-svtune)
This vorks 9 out of 10 tiems.
Old 08-10-2011, 02:50 PM
underthetire is on a distinguished road
If it's singing only on both ends, i would think its more of an issue with a ballscrew alignment.
Old 08-11-2011, 08:14 AM
tc429's Avatar
tc429 is on a distinguished road
I agree- or if its a really used machine, there could be a hourglass wear to the work envelope, and someone adjusted the gibs in the worn center section...weve got a lot of machines in bad shape, see that happen a lot.
Old 08-11-2011, 08:51 AM
CNC Viking's Avatar
I think it is linear bearings here, not gibbs.
Did you try adjusting the parameter(s)?
vibration problem with new machine rppman Knee Vertical Mills 2 11-02-2009 08:58 PM
Need Help!- vibration problem greko Daewoo/Doosan 4 10-21-2008 03:49 AM
In 'X Axis' Having vibration dspjbp Machine Problems, Solutions , Wireless DNC, serial port 0 12-20-2007 12:27 PM
cause of Z axis vibration dahui Shopmaster/Shoptask 5 08-16-2007 09:39 PM
L297 l298 vibration sound problem ez-cnc.com Stepper Motors and Drives 11 04-29-2006 07:29 PM
