Hi I have milling center Shizuoka B3V 410 with fanuc OMc. When I press "power on" on my pcb (A20B-2000-0180/03A), only leds flash L4, L5, L6 leds. Monitor display anything. System is dead. I checked power supply and battery, all voltage on carts are correct. Input module is ok - green led. I checked all switches, limits, sensors - are ok. If I disconnected all card on master pcb only L4 light. L4 is off if I mount memory and I/O card. L1, L2, L3 not flashed ever - it is normal operation?? I have NC/Diagnostic parameters. Ladder PMC is in eeprom. Please help, I don't have ideas. |
| LED Description and Correction L1 Green Blinks during automatic operation. Does not indicate an alarm. L2 Red Lights when an alarm occurs. Appropriate corrective action should be applied according to the alarm number displayed on the CRT screen. L3 Red No memory card has been installed. L4 Red (1) A watchdog timer alarm has occurred. The master printed-- circuit board or memory card may be defective. . See alarm 920. (2) A servo alarm has occurred. (3) No axis card has been installed or, if one has been installed, it may be defective. L5 Red (1) A watchdog timer alarm has occurred in the sub--CPU. Replace the sub--CPU printed-- circuit board. (2) A 5th/6th servo alarm has occurred. L6 Red A system alarm has occurred (1) The analog interface card is defective. (2) The DNC1 card is defective. (3) The 7th/8th card is defective. |
| Thanks drdos. On the monitor connector is not any signal (R, G, B, Hsyn, V syn) - I checked oscilloscope. If I disconnected only memory card L3 no light. My memory card lost parameters so controller should display alarm. Alarm - L2 should light. I think that part of the motherboard control L1, L2, L3 is faulty. Day after tomorrow i replace 80386dx in master pcb. Tips please. |
| Please remember these lights are based on ALL boards being plugged in. If you remove a board then all bets are off as to what these lights mean. If you are sure all memory has been lost and you have a known good backup the try press and hold RESET & DELETE while powering up the CNC. This will clear all memory on you memory board. If that fails the unplug all plugs from the boards to rule out an external short bringing down the system. |
| I did a test: power on + reset + delete is the same. I did a test: all plug disconnected + power on is the same (only blink L4, L5 L6) System dead, the monitor dark. The monitor is not damaged (cathode emits electrons). If you turn on working properly system the leds from L1 to L6 flash? Last edited by sinad; 08-07-2011 at 12:46 PM. |
| Your problem is one of four things. Memory Board, Master Board, Axes board, Power Supply. You are going to need a way to either test these or replace these. If you have another machine with the same controller you might be able to swap out the parts between the two controllers. Be very careful when swapping the memory board as you risk loosing all memory in the other machine as well. |
| I checked my power supply, all voltage, signal and connectors - ok. All boards may correct voltage. I will have to apply a method of swap boards. I trying to find logic in the relationships between cards. Because L4 LED lights up and off axis assuming that the card is correct. Power supply ok PMC assuming that the card is correct. I/O assuming that the card is correct. No video signal - memory card maybe damaged. No lights all led - master pcb maybe damaged. System is complicated and without the knowledge of the service is difficult to diagnose. Thanks drdos I will inform you how I will know more. |
| Your Mother board is OK , It may be a cause Due to Memory , Or graphix card . Are you using a Graphix card or the Cable from CRT is direcrt mounted on the mother board, The processor you removed Check it again Wheather it is properly Fitted in the card or Not? In my 10 Years of Service span I had Never seen a 80386 Faulty , It is having an option of auto shut down . Untill you will not apply any additional Voltage on the Microprocessor It will not faulty in 99% Cases, Fanuc Technology is Excellent, please mail me the complete Problem aloingwith the Picture on prabhatmishra@gmx.com So I can help you ,also please mention the board type (mother board Number or Model A B or C type) |
| Need Help!- Fanuc A20B-0008-0410 (6M Master) | alaih17 | Fanuc | 8 | 10-26-2010 08:40 AM |
| fanuc Ota master pcb | mr pitt | Fanuc | 1 | 12-10-2009 08:22 AM |
| 10t had master pc repaired by fanuc | fanucaholic | Fanuc | 0 | 04-16-2008 10:10 PM |
| Error code ? Replacement cost for a GNO master board? | Skyshark | Fanuc | 3 | 08-21-2007 05:24 PM |
| looking for a 6ta master board a20B-0007-0010 | ezjn | Fanuc | 3 | 05-27-2007 06:21 PM |
